I am new to digital slr photography. I used auto white balance till recently and decided to switch to custom white balance using grey card and shooting in RAW.
I bought the below grey card from ebay.
http://cgi.ebay.com …em5885119d76#ht_500wt_928![]()
I have few questions regarding the usage of the cards.
1. what are the black and white cards used for which I got in the set?
2. I thought that on grey card R=G=B, but different areas of the grey card have different RGB values. Is this normal? How do I know which one to pick?
3. The colors I achieve by using the grey card see to be a bit warmer. What is the right way to do white balance with grey card?
4. If I adjust the exposure in PP later in my final shot, will this effect my white balance as well?
I try to take a grey card shot in the same lighting and same camera settings as my actual shot. I later use this grey card shot as reference to set white balance on all my shots in the same lighting. Once this is done, I adjust the exposure and other settings on the image if needed. Am I following the right sequence of step or missing something?
One more question I have related to White balance is about using Expose to the right technique. If I am using this technique, how do I take the white balance shot? Is it with the +EV or with the correct exposure?
