Thread started 07 Jun 2010 (Monday) 16:46
Solution to bent rubber connection cover?
neonlazer
Jun 07, 2010 16:46 |  #1
So apparently i accidentally stuck the camera back in the case without pushing the covers back fully into the camera..so one came loose and got wedged in the case open..now it springs back out and will be quite annoying..not to mention letting moisture get into the remote/flash connections. Anyone have ideas on how to fix this?(bending it back in place wont work as it has stretched the sides.)
Gear
Bazz8
Gallery: 66 photos
Joined Oct 2003
Jun 08, 2010 06:45 |  #2
The cover is stuffed so perhaps cutting both sides ina v pattern will allow it to sit in place?
worth a try
Gear List : SLR BODIES: Eos 5, Eos 3, D30 ( GIFT TO SON INLAW) 40D( SOLD) 1DMK3 ( Current Body)
LENSES : 28-105 USM ( WENT WITH D30) 50MM1.8 , 20-35MM F 2.8 L , 17-40MM F 4.0 L , 90MM MACRO F 2.8 TAMRON 75-300 F4-5.6 USM , 200MM MK11 2.8 L , 400mm 5.6L
TRYPOD: MANFROTTO 190 WITH MEDIUM FORMAT 3WAY HEAD, MANFROTTO MONOPOD LARGE SIZE.
ccp900
Jun 08, 2010 08:10 |  #3
interesting predicament you got there, now im wondering if canon sells those covers separately
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
EmmaRose
Jun 08, 2010 08:17 |  #4
attach a rubber band around it when its in place so it bends back?
Gear. Flickr. (external link)
oRGie
Jun 08, 2010 09:01 as a reply to  @ EmmaRose's post |  #5
try a little heat, hot hair dryer perhaps, but take the cover off the camera first obviously :)
oRGie - I am an EOS and the 7D was my idea :cool:
http://www.fluidr.com/​photos/orgie (external link)
EF70-200F4LIS - EF-S15-85IS - EF50 1.8II
SkipD
Joined Dec 2002
Jun 08, 2010 09:19 |  #6
Just call Canon's parts department. As far as I know, you can buy any parts that you want to for your camera - especially the external stuff.
Skip Douglas
neonlazer
Jun 08, 2010 10:56 |  #7
I sat the camera in a odd position so it would bend in the other direction and it has gotten better. I will probably try cutting the excess off, also thought about heating it up. I am assuming its not too hard to take it off?
Gear
oRGie
Jun 08, 2010 11:58 as a reply to  @ neonlazer's post |  #8
not taken mine off, but its likely just part of the molding is a little prong that goes in a hole fnar fnar :cool:
1,855 views & 0 likes for this thread, 6 members have posted to it.
1692 guests, 167 members online
