Thread started 08 Jun 2010 (Tuesday) 20:05
BG Change - Help
drdiesel1
Gallery: 86 photos
Jun 08, 2010 20:05 |  #1
Hi
I did my first Fashion Shoot on Sunday 6-6-2010. It was a TF shoot and turned out OK, but I didn't get to use my lighting or BG because another photographer had setup the studio while I was at the MUA's shop.
Anyways, the lighting was not very good.
They used a white Muslin BG . They also used a vinyl walkway. The seam between the two was horrid, so I did what I could with it.
Here's a test shot of the BG. I have CS5, but my Topaz remask is having some kind of memory error and wont open. I think it might be an incompatibility issue with CS5 ?
I need to add a BG to about 30 images before I can finish them. Any help, tips or guidance would be greatly appreciated. Thanks for the help in advance.
Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
Canon 5DMKIII - Canon 24-105F/4L
lehayes
Jun 09, 2010 09:34 |  #2
Are you working in 32 bit or 64 bit, if 64 you might want to try 32 bit with your plugin. Another option with CS5 is to use the "Quick Selection" tool and the new and very improved "Refined Edge" option within that tool.
Larry
Midwest Freelance Photography (external link)
Canon IR Digital Rebel, 20D, 40D, 100-400 L IS, 70-200 f2.8 L, 24-70 f2.8 L, 100mm Macro f2.8, 50mm Macro f2.5, 50mm f1.4, 17-85mm IS, 10-22mm f3.5-4.5, 1.4x TC, 420ex, 580ex, Adobe Photoshop CS5, Lightroom & other assorted goodies..
drdiesel1
Gallery: 86 photos
Jun 09, 2010 15:41 |  #3
lehayes wrote in post #10330661 (external link)
64 bit. Every-time I use the refine edge, it looks worse ? I must be doing something wrong. Thanks
René ­ Damkot
Jun 10, 2010 06:46 |  #4
Well, that image is not so easy to mask...
Do you need to repair the BG, or replace it with something else entirely (color / tone wise)
"Repair" doesn't need such a great selection...
Masking would require a few masks that are added together, since different parts of the image have different contrasts between the model and the background...
Q&D, with a lot of jpg artefacts showing in the mask:
IMAGE: http://img.skitch.com/20100610-46xf4mgakjqyf53mmd1y4wi8j.jpg
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PixelMagic
Jun 10, 2010 07:14 |  #5
Rene is correct, this is not an easy image to mask especially since there is little contrast between the background and the model's hat and top.
Depending on the end purpose there are several solutions. You can try using the Blend-If sliders to replace the background. Otherwise you'd have to use Calculations, Channel masking or some of the more advanced selection techniques.
A few months back someone posted a tutorial using Lightroom to shift colors to make a greyscale image. If you can find it; the tutorial might help a lot. If you posted a hi-res version I'd give it a shot but I can tell you that replacing 30 backgrounds is going to take a fair amount of time.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 10, 2010 10:55 |  #6
Look at the video in the first post in Selecting areas in PS.
drdiesel1
Gallery: 86 photos
Jun 10, 2010 19:24 |  #7
PhotosGuy wrote in post #10337795 (external link)
That was great.
Thanks for the link and thanks to everyone for your ideas and help :cool:
drdiesel1
Gallery: 86 photos
Jun 10, 2010 19:27 |  #8
I searched the Topaz Labs sight and removed the program completely. Downloaded the latest version of Mask 2 and did a reinstall. It works :cool:
All the Topaz Labs stuff is 64 bit compatible. Thanks.
1,798 views & 0 likes for this thread, 5 members have posted to it.
BG Change - Help
1097 guests, 125 members online
