Thread started 29 Jul 2005 (Friday) 09:02
Speedlite set-up
SDJNJ
Joined Jan 2005
Jul 29, 2005 09:02 |  #1
Since realizing that you can't use manual mode with the transmitter & speedlites, I'm trying to figure out a decent set-up. I have 18 in wedding party in church, with 3 speedlites available. I think I'll eliminate the transmitter & use one on camera as master & the other two as slaves bouncing off umbrellas. The set-up I am referring to is on page 33 (the top diagram) of the speedlite manual. Speedlites all using ETTL. Camera is 20D, settings, ISO 200, 1/250, f11. If anyone has time to look & comment on this set-up, I'd sure appreciate it!
Canon 1D Mark IV/1D Mark III/5D Mark II/20D/10D+100-400mmL+24-70mmL+
70-200mmL2.8 IS+17-40L+100mm f/2 macro+50mm f/1.4+85mm f/1,8+1.4 Extender+580 speedlites+STE2+Lightspheres,lumiquest​s,stofens+Jones brackets+CP-E3 battery pack+Pocket Wizards+ studio equipment, etc.
scottbergerphoto
Joined Jun 2003
Jul 29, 2005 09:46 |  #2
You will find alot on this in the Sticky.
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
SDJNJ
Joined Jan 2005
Jul 29, 2005 09:58 |  #3
Thanks, Scott. So far, what I gather from that sticky, is that your main light on your camera should be used as fill or not at all, just as the master to transmit. Which I can easily do with my transmitter. Yesterday, you posted on another thread that you use (2) speedlites, one on stand w/umbrella, one on camera. Do you use your camera as fill, then? If so, you simply use the ETTL, change exposure for each light? Thanks so much!!!
SDJNJ
Joined Jan 2005
Jul 29, 2005 10:29 |  #4
Never mind. I just found my answer in one of your posts! Thanks again!!
robertwgross
Joined Nov 2002
Jul 29, 2005 11:18 |  #5
SDJNJ wrote:
The set-up I am referring to is on page 33 (the top diagram) of the speedlite manual. !
Which manual are you looking at? For which Speedlite?
---Bob Gross---
SDJNJ
Joined Jan 2005
Jul 29, 2005 11:37 |  #6
The 580 manual. Let me know what you think, Bob! I always appreciate hearing from you!!!
1,484 views & 0 likes for this thread, 3 members have posted to it.
Speedlite set-up
1364 guests, 178 members online
