Thread started 11 Jun 2010 (Friday) 03:20
Graphics card choice ? (etc)
Box ­ Brownie
Jun 11, 2010 03:20 |  #1
Hi All
New build planned (W7 64bit, 8gb RAM ideally, i5 Quad Core, 4 HDDs [OS, Scratch, 2 for data]) but not sure about the graphics card???
I hope to upgrade to CS5 in future (CS2 now) and also get LR, now Adobe list these as suitable cards for CS5:-
NVIDIA GeForce
7000, 8000, 9000, 100, 200, 400 series
NVIDIA Quadro FX
x500, x700, x800, FX370, FX380, FX580 series, Quadro CX cards
So again for future 'proofing' (second monitor one day?) I wish to have a card with two DVI outputs & what would be nice if it does not break the bank is for it to have 2 LUTs so each monitor can be independently calibrated.
I do not play games so as long as the other spec like GPU speed and onboard RAM meets the minimum for CS5 I would hope I would be OK. But can anyone suggest (using & experience???) a "best" card ins the above series that fit this bill???
TIA for any insight :)
That was a great meal ~ you must have a good set of pans :p
Images for a photographic memory (external link) | Flickr (external link) | >>>My 500px<<< (external link)
credit line is vanity, payment is sanity
BeritOlam
Jun 11, 2010 04:52 |  #2
If you're not gaming, just about low-end cards these days are more than powerful enough to run CS5 in a dual-monitor setup.
Places like Newegg always have discounted cards each and every week in the $30-50 range w/dual DVI outputs.
Blessed are the young, for they shall inherit the national debt. – Herbert Hoover
Box ­ Brownie
Jun 11, 2010 05:10 |  #3
BeritOlam wrote in post #10342437 (external link)
Thanks for the feedback :)
I should have said that I am in the UK so the likes of Newegg are not on my 'supplier' list :lol:
Though I take from what you say that the most basic version of the nVidia chipped cards listed will do the job ~ just need to Google more deeply to find those will dual DVI and min spec as stated by Adobe.
lsuber
Jun 11, 2010 06:25 |  #4
That's pretty much what I did as well. I knew I would have dual Dell U2311H monitors and I wanted dual DVI outputs so they would have the same connection and all. I got one of the lower XFX Radeon cards with 2 DVI outputs and 1Gb of memory. Has done the trick so far for me. Apparently most of the current generation of graphics cards are overkill for a lot of applications.
Canon 5D Mark II | 28-70mm f/2.8L USM | Σ 70-200mm f/2.8 APO EX DG HSM OS | 85mm f/1.2L USM | Σ 50mm f/1.4 EX DG HSM | 50mm f/2.5 Compact Macro | LR5 | PS CS5
Tony-S
Jun 11, 2010 09:41 as a reply to  @ lsuber's post |  #5
Here's what to look for in a graphics card for PSCS5:
  • supports OpenGL
  • has enough RAM to support Photoshop functions--at least 128 MB of RAM. The recommended amount of RAM for the best experience in Photoshop is 256 MB or more.
  • has a display driver that supports OpenGL 2.0 and Shader Model 3.0
Personally, I wouldn't get any less than 512 mb of vRAM on a card.
Here are the gpu accelerated features:
  • Scrubby Zoom
  • HUD color picker
  • Color sampler ring
  • Brush dynamic resize and hardness control
  • Bristle Brush flotilla
  • Crop with Rule of Thirds grid
  • Adobe Repousse
  • 3D overlays, including ground plane, widget, light widget, bounding box for mesh and materials.
  • Smooth Display at All Zoom Levels
  • Animated Zoom Tool
  • Animated Transitions
  • Hand Toss Image
  • Birdseye View
  • Rotate Canvas
  • Smooth Display of Non Square Pixel Images
  • Pixel Grid
  • Move Color Matching to the GPU
  • Draw Brush Tip Editing Feedback via GPU
  • 3D GPU features include:
    • 3D Acceleration
    • 3D Axis
    • 3D Lights Widget
    • Accelerated 3D Interaction via Direct To Screen
    • 3D Ground Plane
    • 3D Selections via a Hi-light Overlay
If any of those are important to you, you should review the prospective graphics card's specifications to see if they are provided.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
ecub
Jun 13, 2010 00:05 |  #6
Go with at least a 9800, which should be sufficient with currrent apps.
- Ed
Official Gear List
5D II | 7D | 16-35mm f/2.8L II | 24-70mm f/2.8L | 70-200mm f/2.8L IS II | 100-400mm f/4.5-5.6L | 50mm f/1.2L USM | 85mm f/1.2L II | 100mm f/2.8L IS macro
Box ­ Brownie
Jun 13, 2010 04:38 |  #7
Thanks guys for the feedback.
So far I have found that the Quadro FX380 and the GeForce 9600GT have 2 off DVI others have a mix of DVI & Display Port (I have read of a few issues running DVI using an adaptor cable off of DP in 2 monitor usage?) and yet others are DVI, VGA and HDMI outputs ~ odd that so few simply have twin DVI  ???
Edit ~ not ignoring the fact that for a non gamer the graphics card should not be costing more than the rest of the build kit put together :lol:
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jun 14, 2010 11:59 |  #8
GPU CUDA support is the way of the future... CS5 supports some of that. So any nVidia card 8+ series. I myself upgraded my 7600GT for a 8800GT (112 stream processors!). If you want more bang for your money, get something with at least 128 stream processors.
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
aboss3
Jun 17, 2010 12:40 |  #9
You can get away with a cheaper graphics card. I'd suggest nvidia 2xx series. If you can afford it, go with a "beginner" GTX-260. It's a great card for the money. check out newegg - they often have them on sale.
Gear | My gear is changing faster than I can update the signature
VoyageEyewear (external link)
basroil
Jun 17, 2010 17:23 |  #10
If you plan on using Premiere Pro and After Effects, get yourself a GTX285, there's more than just CUDA supported. If you mean only photoshop, skip the video card and get a i7 875 to upgrade your i5 to something better.
Box ­ Brownie
Jun 17, 2010 17:54 |  #11
basroil wrote in post #10380934 (external link)
Hi
Most of what I have done is PS related hence my thought about upgarding to CS5 eventually. I have done and also will do again in future some video NLE but not necessarily sticking with Premiere for this.
I i5 I have selected is Quad core so AFAIK a lot of horsepower for both PS and NLE work especially when I throw in 8GB of RAM ~ and from what I have read & learned so far a CUDA card with at least 256MB of onboard RAM and a multi-streamed graphics card is the target spec.
I take your point now about the i7 875 (quad core & on board graphics) would suit an H55 motherboard but I do want in future to use dual monitors and that route will mean adding a card in future.....?
Budget is not unlimited so unless the GTX285 has dual LUT so each monitor can be independently calibrated the extra £100 is not good!
Edit ~ if using the i7 875 with an H55 chipset motherboard ~ how well does such a system calibrate the monitor using in my case a Spyder 3 Elite? Versus the P55 and a graphics like the GTX260, FX380, GTX285 etc ???
basroil
Jun 17, 2010 23:44 |  #12
Box Brownie wrote in post #10381095 (external link)
Hi
You have to ask Rene about LUT considerations. I'm guessing it's a driver based issue rather than card based one. And CUDA with photoshop is useless (compared to just using a faster processor), might as well just get two of the cheapest cards you can instead. Two 5450 from ati can be gotten for $100, two 210/310 nvidia cards can be had for about $150-200.
1,925 views & 0 likes for this thread, 8 members have posted to it.
914 guests, 117 members online
