Thread started 12 Jun 2010 (Saturday) 11:15
Umbrella Measurements
Gerald3
Jun 12, 2010 11:15 |  #1
I have a very simple question to ask of you knowledgeable people. Are the measurements of umbrellas the Radius or the Diameter of the umbrella? I'm assuming that it's the Diameter, but I'm not exactly sure. The reason I ask is because I plan on getting some basic lighting equipment for this (external link) little number, and I want to make sure that I'm getting the right umbrella size. The distance from my shoulder to the palm of my hand is about 25 1/2", so going by that, I think that I need a 25-27" umbrella for this setup. But as I previously stated, I don't know if the measurement is in Radius or Diameter. BTW, I plan on using a hot shoe sync cord for this, as it's a hell of a lot cheaper than using Canons wireless solution.
Simple question with a simple answer, so which is it? :)
Cheers, Gerald III
1D Mk II | Canon EF 28-105mm f/3.5-4.5 USM II
Wilt
Jun 12, 2010 11:21 |  #2
Diameter certainly...could you imagine the room size needed to support a 36" or 48" radius?! :)
http://www.bonanzle.co​m …nsparent_Umbrel​la_48_inch (external link)
Gerald3
Jun 12, 2010 11:36 |  #3
So I could even get away with hand holding a 50" umbrella then?
Cheers, Gerald III
Wilt
Jun 12, 2010 11:38 |  #4
Gerald3 wrote in post #10348841 (external link)
Unless you are walking in the rain, or shielding yourself from the sun, or serving as an assistant to someone else who is the photographer, hand holding any umbrella is only going to distract you from composing and holding the camera steady while you shoot!
Gerald3
Jun 12, 2010 11:44 |  #5
Well in that case, I'll just mount the umbrella and flash on my tripod with an adapter. Thanks for the info, I'm new to external flash lighting. I've been reading this (external link) article over the past few days and it's been very helpful and informative.
Cheers, Gerald III
1,862 views & 0 likes for this thread, 2 members have posted to it.
2848 guests, 162 members online
