Thread started 13 Jun 2010 (Sunday) 12:17
Comparing the Power Output of an AB400 to a 580 EX II
mattograph
"God bless the new meds"
Jun 13, 2010 12:17 |  #1
Can't put my mind around how to do this, with a meter. My question -- just how much more light, if any, does an AB400 produce?
This space for rent.
Wilt
Jun 13, 2010 13:21 |  #2
AB400 has f/11 + 0.2EV measured at 10' ISO100, using standard 7" reflector which covers 80 degree...about Guide Number 120.
For apples-to-apples comparison, the speedlight has to have its zoom head set to about 26mm (FF) coverage --which isn't available, you likely only have 24mm (84 deg) or 35mm (63 deg) coverage angle to choose from. Set the zoom head to 24mm (84 degree FF) coverage angle, set the f/stop to f/2 and see what distance is displayed, multiply 2*distance to get Guide Number for the speedlight.
Guide Number AB400/Guide Number speedlight = n
If n = 1.414, AB400 puts out 2x as much light (one f/stop)
At 50mm coverage angle, the 580EX has GN130...roughly the same output intensity. Since I don't own a 580EX, I can't tell you the claimed GN for 24mm...and the speedlight claims are always optimistic compared to what you would actually meter!
mattograph
Jun 13, 2010 14:10 |  #3
Wilt wrote in post #10354080 (external link)
Thank you. So the a b800 would roughly put out a stop and a half more?
dmward
Gallery: 29 photos
Jun 13, 2010 14:43 |  #4
Here is the 580EX Gn chart from the manual.
There is a 28mm setting which should closely correspond to Wilt's numbers for an AB400.
Wilt
Jun 14, 2010 00:18 |  #5
28mm only fills 74 degree AOV, which is why I used 24mm for my suggestion...84 degrees AOV is closer to 80 than 74 is.
Using GN92 vs. GN120, the 580EX would be about -0.9EV less powerful than AB400; and about -1.9EV less powerful than an AB800.
But, again, I have to warn that a typical speedlight flash GN is overstated, compared to what a flash meter would measure!
CamPhotog
Feb 22, 2011 17:26 as a reply to  @ Wilt's post |  #6
I actually just did a quick, unscientific, comparison test on this... Here's a blog post with pics / results: http://camaraphotograp​hy.wordpress.com …bees-400-comparison-test/ (external link)
No light meters... In this day and age, with an LCD, I just can't justify the $ for one...
Wilt
Feb 22, 2011 17:37 |  #7
CamPhotog wrote in post #11894311 (external link)
The reason for using a light meter...
  • More accurate relative light output setting (light A: light B)
  • Faster exposure determination
Less trial and error adjustment, using a meter vs. shooting and chimping.
bobbyz
Feb 22, 2011 21:12 |  #8
So your 580ex is more powerful than AB400.
Fuji XT-1, 18-55mm
flowrider
Gallery: 127 photos
Feb 23, 2011 02:03 |  #9
Wilt wrote in post #11894392 (external link)
+1. I never used anything other than a manual camera until digital came along. Heck most cameras I've owned didn't even use a battery! But a light meter is gold and much more accurate than the LCD (when calibrated of course).
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
cristphoto
Feb 23, 2011 09:03 |  #10
mattograph wrote in post #10353721 (external link)
Is the AB400 a 400 ws light? I use Norman ML400 (400ws) monolights and they measure about 2 1/2 stops brighter than my 580 flash (f3.5 vs f8 at same distance and spread - measured with flash meter).
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
TMR ­ Design
Joined Feb 2006
Feb 23, 2011 09:10 as a reply to  @ cristphoto's post |  #11
An Alien Bees B400 is 160 Watt seconds.
Robert
cristphoto
Feb 23, 2011 09:18 |  #12
TMR Design wrote in post #11898230 (external link)
OK. That would be about 1 1/2 stops less than my numbers then. (Confusing name - AB B160 would seem better).
cristphoto
Feb 23, 2011 09:25 |  #13
With histograms now on cameras a flash meter isn't really required. When I set up my lighting I always go by the histogram. Usually in 2 or 3 shots I've nailed the settings.
TopHatMoments
Feb 23, 2011 09:40 |  #14
You might nail the lighting to remove the blinkiezzz but, matching the ambient, or up or down from ambient will be hard pressed.
Setting the amount ( shadow level ) of light and where it will fall off on a face will not show on an LCD
Matching the light from one side to the other, will not show up on an LCD
We can all ( well most of us ) do it by guess and sight but, when you star to wonder how they did that or that lighting is crisp and dead on, it will not have been done by an LCD histogram.
With a light meter, checking light output compared to another would have been but a few clicks away.
Canon to PhotoShop, “Beam me up”! LR3 set course for CS5, Warp speed 64!___ ((dpp___/==***^***
TMR ­ Design
Joined Feb 2006
Feb 23, 2011 10:27 |  #15
TopHatMoments wrote in post #11898369 (external link)
Not to mention the fact that balancing flash with ambient or between strobes can't be done without a light meter. Sure, you (referring to cristphoto) can guess and use the histogram and chimp on the back of the camera but what do you do if you're working on a series of shots and they're done at different locations at different times of day but the look must be consistent?
How would you possibly achieve the same balance between flash and ambient? Are you really going to chimp on each shot and then look and compare on the computer? If not it's not going to happen. That's the perfect example of a shot that needs to be calculated and done by the numbers.
Robert
7,056 views & 0 likes for this thread, 14 members have posted to it.
1592 guests, 137 members online
