Thread started 14 Jun 2010 (Monday) 06:45
580EXII losing settings
allenbirnbach
Jun 14, 2010 06:45 |  #1
I was shooting yesterday, and the recycle time on my 580EX II dropped to the point that I decided to change the batteries. One problem though was that once the batteries were replaced, the flash lost its setting as being in Slave mode. Is there a custom setting that will force the unit to stay in that mode? I could not find anything in the owner's manual.
photoPanda
Jun 14, 2010 06:47 |  #2
If you leave the batteries out for too long it will not save the settings. There isn't a CFn to fix that. If you change batteries in a reasonably quick timeframe you will not lose the settings. Addit: Having extremely flat batteries just prior to changing them may shorten this period; I've never tested that.
allenbirnbach
Jun 14, 2010 07:06 |  #3
Disappointing news, as it really slowed me down in the middle of a job. I probably changed the batteries in under a minute.
Cham_001
Jun 14, 2010 07:24 |  #4
Allen,
It is a huge pain!
Canon have been asked time and time again to re-introduce a Manual Button that allows switching between Master/Slave modes on the EX flashguns!
Have they listened?
Do they listen?
Will they now listen?
"... with a clear perspective - the confusion is clearer ..."
Body: < changing >
Lenses: 70-200mm f/2.8L IS II USM, 24-70mm f/2.8L II USM
Flashguns: 580ex II x 4, MT24 macro flash
Accessories: Pkt Wiz TT5 x 5, AC3 x 2, MiniTT1 x 2, Sekonic L-758DR
Studio Lights: Godox ADpro x 3
sigma ­ pi
Jun 14, 2010 16:04 |  #5
OK i thought i was going crazy. maybe i hit the button while changing them to make it go into master again
Don't try to confuse me with the facts, my mind is already made up.
http://www.flickr.com …6850267535/in/p​hotostream (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jun 14, 2010 17:24 as a reply to  @ sigma pi's post |  #6
More probably the backup capacitor was at such a low level when you removed the depleted battery, that the flash lost memory almost immediately.
Anders
P1et
Jun 14, 2010 17:26 |  #7
I have to agree that it's quite a bit simpler to throw my 430EX into slave mode than it is for my 580EX II...
Canon 50D | Canon EF 24-105mm f/4L IS USM | Canon 70-200mm f/4L | Canon EF 50 f/1.8 | Tokina 11-16 f/2.8 | 580EX II | 430EX | ST-E2
apersson850
Gallery: 35 photos
Jun 15, 2010 04:21 as a reply to  @ P1et's post |  #8
The thing is that a flash like the 580 EX II is desgined to be set up via the camera's menu system. The menu system can't move a mechanical switch like the 580 EX has. Besides, the lock lever on the 580 EX II is much more convenient than the lock nut on the 580 EX, and at least I mount the flash more often than I turn it over to slave mode.
Anders
m3rdpwr
Jun 15, 2010 09:29 |  #9
Rumor of the new Speedlite re-introduces the off/master/slave switch.
But hey, it's a rumor... :)
-Mario
kimmortal
Jun 15, 2010 23:02 |  #10
I guess that might answer the question I was about post a thread for:
My 580EX2 keeps auto-powering off, even though I've changed the custom function to turn that off. Is it my batteries? I used rechargeables, and it seems like it's saving the custom function, but that sucker turns itself off if I stop shooting to adjust something on my set up. Any help?
5DmkII, 30D, 50 1.4, 17-40, 70-200 2.8, Tamron 29-75 2.8. :cool:
www.kimwardphotography​.com (external link)
Cham_001
Jun 16, 2010 01:53 |  #11
Hmmmm,
If 'Auto-Power-Off' is set to 'Disabled' via the Camera-Menu Custom Function 2, then the likely cause is lack of battery-charge/power.
Try with a fresh set of batteries, if this problem re-occurs then it's something else.....
Body: < changing >
kimmortal
Jun 16, 2010 10:30 |  #12
Cham_001 wrote in post #10370749 (external link)
Hmmmm,
Thank you so much! That was my suspicion, but it was kinda weird that the flash would do that (at least in my head). I'll give that a shot. Fresh batteries it is!
1,629 views & 0 likes for this thread, 8 members have posted to it.
2792 guests, 138 members online
