Thread started 14 Jun 2010 (Monday) 19:01
The 17-40L and focusing by using the Hyperfocal Distance Technique
pixel_junkie
Jun 14, 2010 19:01 |  #1
Hi guys, for those of you who are familiar with the Hyperfocal Distance Technique for focusing when shooting landscape or Architecture, how do you do it with the 17-40L? I learned how to do it on a 35L first and have been able to set up my focus without looking into the viewfinder. I'd look at the little scale on top of the lens and knowing what my aperture setting is, I can set up the lens so it focuses from a certain distance to infinity just manually. I would use the viewfinder only to compose the shot. But the 17-40 is a zoom and is set up differently. Is there away to set up my focus the same way I mentioned above? Thanks much in advance!
Website (external link) | Blog (external link)
TooManyShots
Jun 14, 2010 19:10 |  #2
What is the red index number next to the white line, on the distance scale? That index number should be the preferred aperture to use when the infinity mark (a side way L) is place on it. I believe that index number should indicate the zoom range too? If you have to use a different aperture setting, is not possible to use the scale. You probably need to use an online calculator and to plug in the numbers to get the min focus distance, at a specific aperture value, under a specific zoom range.
One Imaging Photography (external link) and my Flickr (external link)
Facebook (external link)
ccp900
Jun 15, 2010 10:10 |  #3
hey pixel, wanna share how you do it with the 35?
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
Willie
Joined Feb 2004
Jun 15, 2010 10:21 |  #4
I don't own either of those lenses, but I'm guessing that the 35L, being a prime, has distance and DOF scales on it. The zoom probably doesn't, so you won't be able to set it the same way.
You'll need to calculate the hyperfocal distance and guesstimate your focusing distance manually.
SeJun
Joined Jun 2010
Jun 15, 2010 16:11 as a reply to  @ Willie's post |  #5
I do it manually using an app. on my cell phone... something like this which you can find on-line (just find one for your cell phone so it will be with you all the time).. and when taking the picture, dial in the hyperfocal distance..
http://www.dofmaster.c​om/dofjs.html (external link)
Comments and critiques are always welcomed and appreciated!
SeJun
5DII
Wilt
Jun 15, 2010 19:37 |  #6
TooManyShots wrote in post #10362202 (external link)
What is the red index number next to the white line, on the distance scale?=.
Red index mark is used only for Infrared film focus...if 10' physical distance, you set 10' mark opposite the red index mark.
Wilt
Jun 15, 2010 19:42 |  #7
With distance marks only at 3' and infinity, it is supremely difficult to focus the 17-40mm at the hyperfocal distance (no matter what it happens to be for any given f/stop or FL)!
The lack of DOF scale on zoom lenses is only a small fraction of the problem of using hyperfocal settings these days.
ah, the joys of modern AF lenses :rolleyes:
pixel_junkie
Jun 15, 2010 20:38 as a reply to  @ Wilt's post |  #8
Hm, okay. I just learned a semi-reliable technique to focus and I can no longer use it, that bites .... So then what would be another reliable way to focus for landscape and architectural photography? How do you guys do it? Focusing on an object which is a third into your scene doesn't seem to be the most reliable method.
Wilt
Jun 15, 2010 21:05 |  #9
pixel_junkie wrote in post #10369245 (external link)
Right, simply because 1/3:2/3 distribution of DOF limits only applies at one very specific focus distance per FL + aperture combination. DOF near and far limits can be 50:50 at macro distances yet can also be 1:99, and every other ratio in between those examples. For example, 100mm lens at f/5.6 focused at 110m has rear DOF at 3895m...2.5% in front, 98.5% in rear!!!
Usually there is a primary subject in a scene, so I simply focus there and hyperfocal DOF is simply dismissed as a useful technique! If there is no primary subject, as might be the case in a landscape, guessing a point out at 1000x FL and then focusing at that point will result in very deep DOF.
BJDrew
Jun 15, 2010 21:08 |  #10
Grab a pen. these numbers are calculated for a 5dII. On a crop body, you may need to focus a touch further away. Your depth of acceptable focus will be from 1/2 the hyperfocal distance (HFD) to infinity.
At 17mm:
f/4 - Set to 8ft.
f/5.6 - Set to 5 1/2ft
f/11 - Set to approx 3ft (2.8ft)
At 24mm (notice how these approx DOUBLE the distances for 17mm?):
f/4 - Set to 16ft.
f/5.6 - Set to 11ft
f/11 - Set to approx 5 1/2ft
At 35mm (notice how these approx DOUBLE the distances for 24mm?):
f/4 - Set to 33ft.
f/5.6 - Set to 24ft
f/11 - Set to approx 12ft
5D Mark II w/ Grip ~ Elan IIe ~ AE-1 ~ FX.
17-40mm f/4L | 24-105mm f/4L IS | 70-300mm f/4-5.6L IS | 24mm f/1.4L |
35mm f/2 | 135 f/2L | Zeiss ZE Makro Planar T* 50mm f/2
BJDrew
Jun 15, 2010 21:13 |  #11
Just to be more clear - the 17-40mm lens really doesn't have much focus travel between 3ft and infinity (maybe 1/8 a turn of the focus knob). I typically use HFD via autofocus.
1) Determine what focal length and f/stop you'll use
2) Eyeball an object at approx the HFD away from you
3) Use AF to lock onto that object
4) Switch to MF
Now you're all set at approx the HFD and knowing the HFD will let you know the nearest object that will appear "acceptably sharp"
4,311 views & 0 likes for this thread, 7 members have posted to it.
1122 guests, 112 members online
