I'm thinking about getting either a TT Change Up and adding at least 1 lens case or building a custom system starting with the belt. My question is, how much load can you carry on just your waist (no shoulder straps) before it gets to be too much?
Jun 15, 2010 23:38 | #1 I'm thinking about getting either a TT Change Up and adding at least 1 lens case or building a custom system starting with the belt. My question is, how much load can you carry on just your waist (no shoulder straps) before it gets to be too much?
Headshotzx Goldmember 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Jun 16, 2010 03:04 | #2 I have (or had, am selling it soon) a Steroid Speed belt and I carried the following:
P51Mstg Goldmember 1,336 posts Likes: 2 Joined Feb 2007 Location: Mt. Carmel, TN More info | Truely, depends on a$$ size and hips so it doesn't slide down. Mine aren't big enough so I need the suspenders, which also redistributes the load (you want to support it with your shoulders)... Too Much Camera Stuff......
Jun 16, 2010 13:53 | #4 Headshotzx wrote in post #10370914 I have (or had, am selling it soon) a Steroid Speed belt and I carried the following: 70-200 2.8IS in whip it out 17-40L in lens changer 25 (usually without lens inside) 580EXII + CP-E3 in lightning fast 750ml bottle in lowepro bottle pouch Canon 50 1.4 and spare batts in chimp cage 1Ds2 with 85L, 1D2n with 17-40L, both on a Cotton Carrier No problems. Pants didn't wanna go down. Why are you ditching it?
Headshotzx Goldmember 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Jun 18, 2010 07:51 | #5 I figured that since I now own the 1D2n, 5D, 17-40L, 70-200, 580EXII, that can last me through any event that I am to shoot. No matter what, the 1D2N and 70-200 2.8L IS are stuck together. If I need a belt, it'll be to hold the bottle, flash, and a couple of primes (currently have only one) and batteries. The solution? Sell away ALL modular pouches and thick belts, purchase 2 x Skin 50 and a thin skin belt and roll (:
Jun 18, 2010 17:45 | #6 Headshotzx wrote in post #10384126 I figured that since I now own the 1D2n, 5D, 17-40L, 70-200, 580EXII, that can last me through any event that I am to shoot. No matter what, the 1D2N and 70-200 2.8L IS are stuck together. If I need a belt, it'll be to hold the bottle, flash, and a couple of primes (currently have only one) and batteries. The solution? Sell away ALL modular pouches and thick belts, purchase 2 x Skin 50 and a thin skin belt and roll (: The single thing that made me want to sell it all was when I bought the Think Tank shapeshifter for cheap (<60% that of retail) which doesn't like the padded pouches that much (they can fit, but not nicely). -Cue Skins product purchase- I've been considering the skins too, particularly the 75 Pop Down for a 100-400. The only problem I can see with the skins is that it looks like the top flap might get in the way while juggling lenses. I found a local store that had a Skin Strobe in stock and it looked like I could stick the flap inside, against the back wall, essentially making it an open top pouch. Would that work on the Skin 75? My goal is to be able to dismount a lens and drop it somewhere safe without needing a third hand.
NicolasRubio Goldmember 1,152 posts Joined Sep 2006 Location: Buenos Aires, Argentina More info | Jun 18, 2010 18:42 | #7 It depends whether you use the Pro Speed Belt or the Steroid Speed Belt. The Steroid can hold a lot more weight comfortably without needing the Pixel Racing Harness. Check my sig for details and ask me anything you want! Gripped 7D - 3 Ls - 3 non-Ls - 580EX II - Too much Think Tank gear - Cotton Carrier Holster
kevinmcdade Senior Member 603 posts Joined Jan 2008 Location: McKinney, TX More info | Jun 18, 2010 19:00 | #8 How well does the Cotton Carrier work with the TT belt system? I've been thinking about getting one to hold the camera body that I'm not shooting with. -KMc-
NicolasRubio Goldmember 1,152 posts Joined Sep 2006 Location: Buenos Aires, Argentina More info | Jun 18, 2010 19:04 | #9 kevinmcdade wrote in post #10387390 How well does the Cotton Carrier work with the TT belt system? I've been thinking about getting one to hold the camera body that I'm not shooting with. On the Pro Speed Belt -> Almost impossible to attach due to the belt's thickness. Gripped 7D - 3 Ls - 3 non-Ls - 580EX II - Too much Think Tank gear - Cotton Carrier Holster
kevinmcdade Senior Member 603 posts Joined Jan 2008 Location: McKinney, TX More info | Jun 18, 2010 19:27 | #10 NicolasRubio wrote in post #10387406 On the Pro Speed Belt -> Almost impossible to attach due to the belt's thickness. On the Steroid Speed Belt -> FLAWLESSLY I'm glad I asked before ordering...I've got the Pro Speed Belt so I will probably end up with a digital holster instead. Thanks for the information! -KMc-
| Latest registered member was a spammer, and banned as such! 2706 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
