Thread started 16 Jun 2010 (Wednesday) 09:29
Blurry Focus in 50d
karijcrossphotography
Joined Jun 2010
Jun 16, 2010 09:29 |  #1
Can anybody maybe explain what I am doing wrong with my 9 pt. option for focusing? Whenever I want to use all 9points, only a few will light, and when the image comes out, 95% of the time, the center is always out of focus and the outer edges are completely clear. How do I get a full image in focus w/o having to go manual?! Thank you!
philwillmedia
Jun 16, 2010 09:30 |  #2
pics would be useful
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
crn3371
Jun 16, 2010 09:32 |  #3
First, you're much better off selecting the focus point yourself rather than let the camera trying to figure out what it is you want in focus. Second, you need to realize that depth of field also controls how much of your image will be in focus and that aperture controls depth of field.
billybookcase
Jun 16, 2010 09:33 |  #4
increase your f-stop to f/16 and or f/22 and then a lot of things will be in focus!
Joined Jun 2010
Jun 16, 2010 09:36 |  #5
i considered the fstop... however, was confused that the center was out of focus and the sides were in focus! i usually use the center point focus... so, using that along with a higher fstop would make sense!! thank you.
gjl711
Jun 16, 2010 09:37 |  #6
As mentioned, a sample pic, one that you consider to show the effect your describing would help. Don't strip the EXIF, that info helps as well.
As to why the focus points are doing what they do, that's normal, the points that light up are the ones that have achieved focus. The others are outside of the focal plane. If you have been shooting a point and shoot type camera before, keep in mind that a SLR will have a much narrower depth of field, it can at times be very thin indeed depending on the settings. But post up a pic and we will help however we can.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
ingraman
Jun 16, 2010 09:38 |  #7
You have to manually select your focus point in order to get what you want in focus. There's really no way around it. The computer in the camera really isn't smart enough to "know" what you want in focus. When you have all 9 points selected, it just gives you its best estimate based on the points that light up. I would say 90% of the time it guesses wrong.
Especially since you have a 50d and the nice joystick, shouldn't be too hard to pick center point.
bacchanal
Jun 16, 2010 10:13 |  #8
ingraman wrote in post #10372071 (external link)
+1
Set Custom Function III-3 to 1: Multi-Controller direct, and then you can use the joystick to easily select your focus point.
egordon99
Jun 16, 2010 10:40 |  #9
karijcrossphotography wrote in post #10372061 (external link)
Will you didn't instruct the camera to focus in the center of the frame. By using "All 9 focus points", you are telling the camera "Hey, I really don't care where you focus, so go nuts...."
3,877 views & 0 likes for this thread, 8 members have posted to it.
Blurry Focus in 50d
1012 guests, 110 members online
