Thread started 16 Jun 2010 (Wednesday) 12:44
D-lire 4 v Bee's 800
BigStig
Some say that he is a CIA experiment that went wrong, and that he only eats cheese...
Jun 16, 2010 12:44 |  #1
I know most of the people on here seem to use the Bee's for Indoor Sports and they appear to have a great following. Does anyone use the Elinchrom D-Lite 4?? Is it comparable ?? would it do as good a job. I like the Sky Port feature and the ability to adjust power without having to get to the lights all the time. I realize at indoor sports they would probably be on full power but I am also thinking about some portrait stuff.
Thanks for your opinions. Cheers SteveP
Cheers SteveP
http://stevephilipson.​com/ (external link)
My Gear CPS Member
POTN Feedback https://photography-on-the.net …rch.php?searchi​d=25290946
Playonpics.com
Jun 16, 2010 13:14 |  #2
they have the same bulb pretty much...
I'm in a similar issue. But i think i will be going to the Elinchrom, since its a better long term decision, as well the wireless triggers built in now put it over.
I just wouldn't fire them in a burst mode constantly, if so your going to need alot of bulbs..
Canon 1D MarkIII | Canon 7D | 70-200mm F/2.8L | 24-70mm F/2.8L| 300mm F/2.8L IS | 50mm f/1.8 | 85mm f/1.8 | 15mm f/2.8 Fisheye | 580EXII Flash | Computrekker | ThinkTank roller and beltsystem | Elinchrom (2) Dlites 4IT Canon Platinum CPS Member
www.playonpics.com (external link)
AdamLewis
Jun 16, 2010 17:18 |  #3
I cant find a t.1 on the D-lite4. That would be a pretty big factor...
canonnoob
Jun 16, 2010 17:22 |  #4
also, the skyport triggering system isnt nearly as reliable as the cybersync system. just my .02
as far as adjusting power, get there early and get set up... make sure you have enough time to make those adjustments. If you do that, you dont have to worry about changing lighting conditions.
David W.
AdamLewis
Jun 16, 2010 17:24 |  #5
From what I read, the quoted 1/800 flash duration that I see here and there is more like a t.5 at best which means you will have an abysmally slow t.1. If youre planning on using these for sports, I would most definitely go the AB400 route over the Elinchrom (and this is coming from a guy who loves Elinchroms...I just happen to love their 600RXs haha).
dmwierz
Jun 16, 2010 20:05 |  #6
FWIW, one of the pluses of the AB800's is they are small and lightweight. As they have spent a lot of time atop 13' light stands at HS basketball games, this makes them much more stable (and safer) than larger, heavier strobes.
http://www.denniswierz​bicki.com (external link)
http://www.sportsshoot​er.com/dmwierz (external link)
Dennis "
Yeah, well, sometimes nothin' can be a real cool hand."
DDCSD
GIVIN' GOOD KARMA
Jun 21, 2010 19:15 |  #7
The D-Lites have too long of a flash duration for sports.
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
BigStig
Jun 23, 2010 09:57 |  #8
I'm probably going to go Alien Bees.
Just as a thought how are the next level up Elenchrom I think it is the BXRI 500 ?
Cheers SteveP
My Gear CPS Member
AdamLewis
Jun 23, 2010 10:00 |  #9
BigStig wrote in post #10412568 (external link)
I dont know anything about them. What is the flash duration?
AdamLewis
Jun 23, 2010 10:09 |  #10
Elinchrom's website says that t.5 on the 500 light is 1/1558. That means t.1 should be somewhere around 1/500... Personally, Id rather have something faster than that for sports.
3,298 views & 0 likes for this thread, 6 members have posted to it.
1605 guests, 140 members online
