To be honest, I'm scratching my head on this one. It seems like whatever's getting thrown off is intermittent; I've got photos here, some of which are OK, some soft down the left, but if there's softness it's mostly down the right (including some taken upside down).
In pursuit of something more scientific, though, I rigged up some squares on a book-case. This is the "reference" image, taken with the 18-55 IS (on a tripod, with IS enabled; Mk.IV IS is supposed to detect this) at 18mm (processed in DPP to remove CA and vignetting):
| HTTP response: NOT FOUND | MIME changed to 'image/png' |
To my eyes, this seems pretty much the same in all corners. (And not too bad, either.) Now this is the 15-85 at 15mm, wide open at f/3.5:
and slightly more marginal here at 24mm, f/4.5:
Seems like the bottom right is out of kilter.
I'm not sure if these account for the first image I posted (which was taken with IS off). In its defense, I will point out that the DoF at 15mm when focusing on something 30m away is basically 3m to infinity, so the entire image
should be in focus. I can only guess that maybe the IS element isn't parking properly. Grr.
CAAAANNNNNOOOOONNNN...
