Is there an adapter that can securely attach a camera to a lightstand boom arm. I want to do overhead shots.
texshooter Senior Member 652 posts Likes: 26 Joined Jun 2009 More info | Jun 17, 2010 16:49 | #1 Is there an adapter that can securely attach a camera to a lightstand boom arm. I want to do overhead shots.
7D_Sniper Goldmember 2,204 posts Joined May 2010 Location: South FL More info | Jun 17, 2010 17:43 | #2 just make something your self some angle iron/bolts some good ole DIY Run it's the big bad amateur
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Jun 17, 2010 17:49 | #3 There are adapters that will allow you to do this. I dont have a link to share though. Or get something like the Magic Arm.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jun 17, 2010 17:55 | #4 Highly vibration prone way of shooting, unless you will be using a radio remote to fire the camera, and even then the reflex mirror might cause enough vibration (it can, even on a tripod, which is more vibration resistant than a light stand and boom arm) Shooting in a dimly lit room with electronic flash illumination would address the vibration issue, but not if available light is bright. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
RayHff Member 111 posts Joined Dec 2009 More info | Jun 17, 2010 18:33 | #5 A ProSystem Clamper will clamp to just about anything.
ecub Goldmember 1,487 posts Joined May 2010 Location: Southwest suburbs of Chicago More info | Jun 17, 2010 23:07 | #6 A monopod with a ball head? - Ed
R-C-G Member 109 posts Joined Mar 2008 Location: Portland, OR More info | Jun 18, 2010 00:25 | #7 In the past I've used super clamps with a stud screwed directly to the camera. Also using a background stand instead of a boom makes for a much more stable setup. gear
| Latest registered member was a spammer, and banned as such! 2695 guests, 162 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
