Camera = 40D / Lens = 100mm F2.8 Macro USM / Flash = MT-24ex
Photoshop Editing = None
Photoshop = Re-sized only
(simply opened in CS3 and reduced file to comply with 150kb limit)
Original EXIF available
Please be ruthless!
Cham_001 Senior Member 880 posts Likes: 58 Joined Feb 2009 Location: based between Ruse, Bulgaria & Recife-Brazil More info | Jun 19, 2010 10:48 | #1 Camera = 40D / Lens = 100mm F2.8 Macro USM / Flash = MT-24ex "... with a clear perspective - the confusion is clearer ..."
Jun 19, 2010 23:14 | #2 i like it. i think if you would have bumped up to a higher f stop that would be even better, but that just my opinion. Canon 6D
racketman Cream of the Crop More info | Jun 20, 2010 11:18 | #3 looks sharp enough but Canon do recommend use of USM in Photoshop. Toby
Cham_001 THREAD STARTER Senior Member 880 posts Likes: 58 Joined Feb 2009 Location: based between Ruse, Bulgaria & Recife-Brazil More info | Jun 20, 2010 17:52 | #4 @ BlakeG - thanks for the tip - I will certainly select a smaller aperture for 'sharper' shots "... with a clear perspective - the confusion is clearer ..."
racketman Cream of the Crop More info | Jun 20, 2010 19:47 | #5 Cham_001 wrote in post #10396625 @ BlakeG - thanks for the tip - I will certainly select a smaller aperture for 'sharper' shots ![]() @ Racketman - thank you. I do not understand this point. Why must I resort to editing images using Unsharp Mask (USM) for 'Sharp(er)' photographs? because that's the way the dslr cameras are set up - ie with minimal in camera processing unlike compacts. A lot of people take their new dslr straight back to the shop when they see the out of camera shots on their screen complaining their P&S was much sharper. Toby
Cham_001 THREAD STARTER Senior Member 880 posts Likes: 58 Joined Feb 2009 Location: based between Ruse, Bulgaria & Recife-Brazil More info | Jun 21, 2010 01:01 | #6 racketman wrote in post #10397045 because that's the way the dslr cameras are set up - ie with minimal in camera processing unlike compacts. A lot of people take their new dslr straight back to the shop when they see the out of camera shots on their screen complaining their P&S was much sharper. As a guide Canon suggest using USM 300/.3/0 - see pages 30 to 31 I don't understand posters (not you) on some forums stating that 'no sharpening was applied' as if it is cheating - you are meant to sharpen! This applies especially to RAW of course but even most jpegs need some work though you can of course set sharpening to a degree in camera. My 135mm prime can produce pretty sharp images but even so a little USM will make a difference. Toby, huge thanks for this bit of enlightenment! "... with a clear perspective - the confusion is clearer ..."
racketman Cream of the Crop More info | Jun 22, 2010 17:02 | #7 You will find loads of info on sharpening Nikon images in relevant forums, people endlessly debate different workflows, whether to turn off in camera jpeg sharpening etc. Toby
| Latest registered member is semonsters 1513 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
