Thread started 19 Jun 2010 (Saturday) 23:02
7d questions
musso
Jun 19, 2010 23:02 |  #1
i sent my 7d in for an AF repair. is it common practices by canon to shoot 6087 images on my camera before returning it to me? i have never reset the count in the camera and the card i use has not been in any other camera.
thank you
joe
JadedDjay
Joined Jun 2010
Jun 19, 2010 23:04 |  #2
anything interesting? jk your file numbering probably set to continuous and it just picked up where the previous numbering left off in the card that they used
just a guess
musso
Jun 19, 2010 23:19 |  #3
i did not think about that so shouldn't my card reset it.
garycoleman
Jun 19, 2010 23:26 |  #4
when I sent my 7d in for AF problem, they shot ~100 pics each time
Canon 5D MKIII | Canon 60D | 24-70mm f/2.8L II | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
musso
Jun 19, 2010 23:31 |  #5
i wouldn't mind 100 but 6087 that's a little excessive. im going to call them Monday and see what they say.
Bill ­ Boehme
Enjoy being spanked
Gallery: 38 photos
Jun 19, 2010 23:52 |  #6
musso wrote in post #10393150 (external link)
You might want to consider that it would hardly be possible for them to shoot that many images -- much less actually look at them. There are a number of possibilities that could account for the large jump in the image count. They may have temporarily changed the image numbering option as a part of their testing. Their CF cards get used in a number of cameras which could account for the change in the number of images. If it really bothers you, you can easily reset the count back to zero.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
JadedDjay
Joined Jun 2010
Jun 19, 2010 23:54 |  #7
musso wrote in post #10393106 (external link)
not unless you manual reset it first... if they reset your camera then tested it with a different card then sent it to you, it doesnt matter what card you put in. do a factory reset and put the card back in where your files left off and im sure it will be the same again
to think that they did more than 6000 frames is just silly. who would waste their time doing that? its just not probable
musso
Jun 20, 2010 00:05 |  #8
i just want to know why it happened and if it was there card that did it then why my card wont bring it back. so every time i send my camera back for service or what ever i have to look forward to having my shutter count go up thousands of clicks. well i don't think it would be to hard for them to shoot that many images take a look at the first few and then the last few. but i do agree that it would be foolish to shoot that many to test. i am just curious as to why.
thank you
joe
krb
Jun 20, 2010 00:23 |  #9
musso wrote in post #10393256 (external link)
The counter will never go backwards based on a card, but it will move forward. The whole point is to make sure that the same number is not used twice and moving the counter backwards could cause a number to be duplicated.
Imagine going to an event with 2 cards. You start off with a card that has been used for 400 shots and you take 200 shots, so you have fileneames IMG_0400 through IMG_0600. Now the card is getting close to full so you swap to the other card, and this other card has been used for 500 shots in the past. If the counter were moved back based on this new card and you took another 200 shots then you would have file names IMG_0500 through IMG_0700. Now you get home, fire up the computer, create a folder for the event and start downloading all of the images. The first card will download fine but once you start downloading the second card you will discover that filenames 0500 through 0600 have been used twice. If you are paying attention you will realise the problem, curse a little bit and create a new folder to hold the images from teh second card. If you are not paying attention you will overwrite the files from the first card and end up losing 3/4 of your images from the event.
This is why Canon does not move the counter back when you insert your old card.
-- Ken
Gear list
Bill ­ Boehme
Enjoy being spanked
Gallery: 38 photos
Jun 20, 2010 00:55 |  #10
thank you
joe
I think that you just got a rational explanation of how it happened and also how to reset it back to where the count left off when you last used it (provided that you did not erase the card).
lannes
Jun 20, 2010 02:18 as a reply to  @ Bill Boehme's post |  #11
Have you seen Ferris Buehlers day off, the scene where he drops his dad's ferrari off at the parking garage.:lol:
artyman
Sleepless in Hampshire
Gallery: 17 photos
Jun 20, 2010 02:59 |  #12
The answer is to change the camera to reset each time, insert a card with no shots on it. Take one shot, remove that card, then insert your normal card and it will carry on from the last number on that is on that card. Then reset the camera back to continuous count.
Ken
Lone ­ Rider
Joined Jun 2010
Jun 20, 2010 03:28 |  #13
WTF...this dosen't sound right at all....
Trevor
Canon 5D3 24-70L 70-300 DO IS 18-55 Sigma 10-20 430EXII BACKUP: 550D
Dereksalem
Jun 20, 2010 04:12 |  #14
thank you
joe
Don't worry, it has nothing to do with how many shutter actuations they used on your camera. It's purely a product of the CF card that was used. As has been said already numerous times they most likely put in a CF card that had images on it from a camera with a higher count. It transferred over to yours. There's no way to reverse it except to format the card and then reset your camera to default settings. Then it'll start over again (IMG_0001)
NinetyEight
"Banned for life"
Jun 20, 2010 07:02 |  #15
It sounds like they put in a card with a higher shutter count:
THIS thread (post #4) may help restore from where you left off.
It comes from a link in THIS other thread on POTN
Kev
2,838 views & 0 likes for this thread
7d questions
Latest registered member is StevePB
885 guests, 221 members online
