Does anyone make a case for three Canon 580 flash units and some associated wireless triggers, etc...? Or is a Pelican case w/Pick N Pluck foam the best solution?
mitchman Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 20, 2010 11:47 | #1 Does anyone make a case for three Canon 580 flash units and some associated wireless triggers, etc...? Or is a Pelican case w/Pick N Pluck foam the best solution? 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 20, 2010 12:26 | #2 I'm looking at the Pelican 1490 case. 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
CafeRacer808 Senior Member 364 posts Joined Dec 2009 Location: Southern California More info | Jun 20, 2010 12:41 | #3 Approximate dimensions of 580exII folded flat: 7.5" x 3" x 2.75" Dave d-.-b
Franko515 "doped up on pills" 2,478 posts Joined May 2006 Location: Crete, Illinois More info | I also have 3 flashes I carry Light, composition, shooting technique matter to the end quality most. -Pekka
Dustman Senior Member 885 posts Likes: 23 Joined Mar 2010 Location: New Jersey More info | I hold my 2 580exII's, 2 Stofen bounces, ST-E2, battery charger and extra batterys in the Lowepro Nova 170 AW. I think I could definitly get a third flash in there too without a problem. I recieved this bag for free from B&H with my 5d MK II. I didnt need a camera bag, but then realized how perfect it was. it really seems like it was made for this bag, the height of the bag & demensions are perfect for this flash!! Comes in 4 colors, and is $50 new & $40 used from B&H
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 20, 2010 14:06 | #6 Thanks for the measurements CafeRacer808! I like the case suggestions from Franko515 and Dustman, but I'm also still considering a Pelican case. But it doesn't look like they make one that would be the ideal dimensions. 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
Palladium Goldmember 3,905 posts Likes: 2 Joined Dec 2005 Location: Not the Left Coast but the Right Coast - USA More info | Jun 20, 2010 14:13 | #7 mitchman wrote in post #10395023 Does anyone make a case for three Canon 580 flash units and some associated wireless triggers, etc...? Or is a Pelican case w/Pick N Pluck foam the best solution? take a look at some of the Think Tank cases like the Chimp Cage
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 20, 2010 20:02 | #8 It's hard to find photos of the inside of the cases you're all recommending. Would I dump the flash units into one large space (they rub against each other) or would they be protected in their own padded compartments? 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
Franko515 "doped up on pills" 2,478 posts Joined May 2006 Location: Crete, Illinois More info | Jun 21, 2010 05:24 | #9 mitchman wrote in post #10397112 It's hard to find photos of the inside of the cases you're all recommending. Would I dump the flash units into one large space (they rub against each other) or would they be protected in their own padded compartments? I like the size of the Chimp Cage and the Nova 170 AW, but it's hard to determine if the individual flash units would be protected. I can take photos of my flashes in the cases mentioned above if you care to see. Light, composition, shooting technique matter to the end quality most. -Pekka
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 21, 2010 08:05 | #10 That would be great. Thanks Frank. 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | I use my Lowepro Nova 4AW for my lighting stuff. It fits my two speedlights, all my triggers, my Sekonic meter, as well as all my AA batteries, memory cards, camera batteries. My umbrella actually fits nicely in my MiniTrekker (the top pocket) and my lightstand is caseless for now.
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 21, 2010 13:45 | #12 What do you guys think of this case? (I'm looking at the Model 8 Grab and Go bag, but maybe the original Roll Up Bag that just holds lightstands would be better) 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
NewAgeVisions Member 93 posts Joined Jun 2010 More info | Jun 21, 2010 14:01 | #13 It only holds 2 stands and 2 strobes. The 13 holds 3 strobes. But, only 2 stands. mitchman wrote in post #10401549 What do you guys think of this case? (I'm looking at the Model 8 Grab and Go bag) http://www.standbagger.com/ I like the fact that you can store your stands, flash units and umbrellas all in one case. The guy in the second video (under the VIDEO tab) says that he even flies with the bad frequently. I would think that the flash units are too exposed for air travel. They could easily get crushed. Thoughts? NIKON F3, 4 bronica gs, 50mm, 65mm, 2 100mm, 2 110mm, 2 200mm, 12 backs, pro hood, 3 Polaroid backs. 3 Kodak 8x10 multiple lenses. Kodak 5x7 3 lenses. Graphic view 2 4x5 with multiple lenses. Canon t2i 5dmk2 14mm 2.8, 24mm 1.4 ii, Sig 50 mm 1.4, 85mm 1.2 ii, ts-e 90mm, 200mm 2.8.
mitchman THREAD STARTER Senior Member 254 posts Joined Apr 2010 Location: Eastern Washington State More info | Jun 21, 2010 18:19 | #14 NewAgeVisions wrote in post #10401641 Love this one, but pricey.. http://www.adorama.com/LWC1048.html Nice! Like you say though....expensive. 5DM2, 70-200 f/2.8 IS II, 16-35 f/2.8, Really Right Stuff BH-55 LR, Gitzo GT3531
NewAgeVisions Member 93 posts Joined Jun 2010 More info | It is funny. We want the bag to carry $1600 worth of flashes, $200 worth of stands, $800 worth of PocketWizards, $400 worth of modifiers. But, don't want to spend more then $70 on the bag.. LOL NIKON F3, 4 bronica gs, 50mm, 65mm, 2 100mm, 2 110mm, 2 200mm, 12 backs, pro hood, 3 Polaroid backs. 3 Kodak 8x10 multiple lenses. Kodak 5x7 3 lenses. Graphic view 2 4x5 with multiple lenses. Canon t2i 5dmk2 14mm 2.8, 24mm 1.4 ii, Sig 50 mm 1.4, 85mm 1.2 ii, ts-e 90mm, 200mm 2.8.
| Latest registered member is semonsters 1053 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
