Thread started 21 Jun 2010 (Monday) 08:46
Moon 06-20-2010
paul3221
Jun 21, 2010 08:46 |  #1
IMAGE: http://www.pauldekort.com/06-10reduced.jpg
Took a series last night through a Celestron 4SE. I find the hardest part is getting the focus just right through a telescope. The hot phoenix air probably didn't help either. Does this look too dark? It looks dark on one of my monitors, and just right on the other. Obviously I need to do some sort of calibration... ;-)a Thanks for looking..
Paul
Paul
Sony A7RII, 5DII, a bunch of lenses and lighting... Whatever gets the shot... ;-)a
www.PaulDekortPhotogra​phy.com (external link)
Facebook Photography Page (external link)
500px (external link)
tkerr
Jun 21, 2010 09:33 |  #2
All in All you have a good image here.
IMHO, it doesn't look too dark, but does look a little focus soft. A little USM does help your image. If you're using photoshop use the UnSharp Mask set at 300%, 0.7px, 0 Threshold. And then you can adjust the levels and contrast just slightly. Doing that will show a significant improvement.
Tim Kerr
F1, try it you'll like it.
paul3221
Jun 21, 2010 23:02 as a reply to  @ tkerr's post |  #3
Tim,
As always, you are a great help! I did the tweaks that you suggested, and played a little in PS. I think it made it look much better.
IMAGE: http://www.pauldekort.com/06-10reduced3.jpg
Paul
QueenChatty
Jun 21, 2010 23:22 |  #4
I think that was the ticket. Looks great!! How much of a crop did you have to apply?
5D MarkII | 50D Canon 17-40mm|55-250 | 60mm Macro | 50mm 1.4 | 24-105L IS | 580EXII | 70-200L F2.8 IS II | Ultra Zap 800 |StarFlash 300 X2 | AB 400X 2 Flickr  (external link)
paul3221
Jun 21, 2010 23:33 |  #5
QueenChatty wrote in post #10404515 (external link)
Actually not much crop at all. The telescope itself is 1350mm, so I actually had to tilt the camera to make it fit better. A full moon barely fits. I have to adjust constantly to keep the moon from moving out of frame.
Paul3221
Paul
moonyguy
Joined Jun 2010
Jun 21, 2010 23:38 |  #6
Looks good. Thanks for sharing. I would let the scope cool for a few hours before shooting to beat the thermals off the glass. Usually I leave my scope out an hour or so before sunset and let it acclimate to the ambient temperature so by the time I come out to shoot 2-3 hours later it has cooled significantly. Adding a simple computer fan to the back of the mirror does wonders to the cooling time.
clear skies
Vishnu
Vishnu Reddy, PhD
paul3221
Jun 22, 2010 08:27 |  #7
moonyguy wrote in post #10404575 (external link)
clear skies
Vishnu
Does this apply the other way too? Here in Phoenix at this time of year, it is usually in the 90's until after midnight. It was close to 100 when I shot this around dusk.
Paul
tkerr
Jun 22, 2010 09:33 |  #8
paul3221 wrote in post #10405955 (external link)
Cooling is a term used by amateur astronomers when we refer to allowing the telescope to equalize with the outside temperature. It doesn't necessarily really mean to cool down, it could mean to warm up like you say in the summer months.
Typically about an hour is good, but if you're using a closed Cassegrain telescope you should allow longer, and if you can use a cooling fan on the back end of the telescope.
BTW, the image does look better with those little tweaks.
Tim Kerr
1,804 views & 0 likes for this thread, 4 members have posted to it.
Moon 06-20-2010
1089 guests, 126 members online
