FORUMS Post Processing, Marketing & Presenting Photos Presentation & Building Galleries
Thread started 21 Jun 2010 (Monday) 14:11
Why online gallery picture look dull?
czynot
Jun 21, 2010 14:11 |  #1
After uploading pictures to Photobucket or flickr. The image is wash out or tone down compare to original jpeg file.
Original picture are view in ACDsee sRGB color space. Picture is save in PS CS5 sRGB. Color sRGB color managment used. All the setting is set to sRGB in my computer.
Why is the color tone down in web gallery? If I download the full image and open in my computer. The color look correct.
Do web gallery use different color management? or Am i doing something wrong?
5D MKII, 24-70mm L, 18-55mm IS,70-200mm 2.8L IS, 50mm 1.8, 100mm Macro, 2-580EX
jrosephoto
Jun 21, 2010 15:45 |  #2
Have you tried the save for web feature in photoshop. That should help.
'Don't be repressed in your work, dare to experiment, consider any urge, if in a new direction all the better.' - Edward Weston
http://instagram.com/j​rosephoto7 (external link)
http://www.jeremiahros​ephotography.com (external link)
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Jun 21, 2010 15:48 |  #3
jrosephoto wrote in post #10402239 (external link)
That will just make the file size smaller and strip the exif, it will not improve the image for online viewing. Will it?
Neil - © NHR Photography
jrosephoto
Jun 21, 2010 16:36 |  #4
neil_r wrote in post #10402265 (external link)
To a certain extent. It will show only web colors, so you will get a better idea of how the image will look.
jrosephoto
Jun 21, 2010 16:38 |  #5
czynot wrote in post #10401704 (external link)
Is your monitor calibrated? Is it only your images that are toned down or do all of the images that you view online look dull? Have you looked at them on different monitors?
Blueskies505
Jun 22, 2010 02:12 |  #6
When you save your photograph, save it in sRGB. This makes a huge difference, sRGB is made especially for windows web browsers color, so the colors tend to be more vibrant and contrasty as you may have shot your photograph. Good luck!
Dawn Marie
Gear: 5D Mark II, 20D, [COLOR="Gray"]35mm1.4 L, 85mm1.2L, 24-105 F4 L 580 EX II, 430 EX II
Foreverpicturesque.com (external link)
rwong2k
Joined Aug 2004
Jun 23, 2010 00:05 |  #7
I have the same problem and save for web resolves the issue, but how do I save an image to reflect the true colours of my monitor but with the exif information?
5DMK3 + Contax CY Lens
http://rw-photography.ca/ (external link)
http://www.facebook.co​m/RwPhotographyVancouv​er (external link)
Go ­ Down, ­ Moses
Jun 23, 2010 08:40 |  #8
rwong2k wrote in post #10410730 (external link)
Saving it in SRGB works for me.
See My Images of Texas:
http://www.tracesoftex​as.com/ (external link)
rwong2k
Joined Aug 2004
Jun 24, 2010 00:40 |  #9
it's weird on my system
save as web the colours are fine, save as the colours are blank,
i made sure it's in RGB mode and i tried turning on and off the colour profile option in save as
the reason I don't want to use save as web is because i wanted the exif information attached =(
help?
thanks!
Raymond
rwong2k
Joined Aug 2004
Jun 24, 2010 17:59 |  #10
I figured out the problem but not too sure how to fix it
if i open up the photo and goto edit > convert to profile and then to srgb it's fine
How can i default the profile to srgb?
thank-you
Raymond
jrosephoto
Jun 24, 2010 18:42 |  #11
rwong2k wrote in post #10421327 (external link)
thank-you
Raymond
Depending which photoshop you are using, you can change the default under edit, and then click on color settings. If you are working in ACR, then click on the link at the bottom of the page and it will load up a box that you can change the defaults.
Mark1
Jun 24, 2010 21:46 |  #12
The problem is not on your side. The problem is the compression that the websites use. Every tiny bit saved on each photo adds up fast whan you have millions of photos in your servers.
The save for web feature is a good semi solution. Photoshop has a much better algorythem than any website does. And the less the website does the better the results. I say semi solution because they will still try to compress the image. But as you did most of it already. They do not have to do to much more.
Another reason is most web browers are not color managed. It simply shows a best guess. And doing so does not allways get it right.
jrosephoto
Jun 24, 2010 23:21 |  #13
Mark1 wrote in post #10422437 (external link)
Very well said...+1
René ­ Damkot
Jul 03, 2010 06:38 |  #14
jrosephoto wrote in post #10402508 (external link)
Not true for jpg. (which is what you should use for photos)
http://www.getcolorman​aged.com/color-management/saveforweb/ (external link)
Save for web in PSCS4 can automatically convert to sRGB. My guess is that's the difference.
rwong2k wrote in post #10417075 (external link)
And what color profile would that be in "Save as"?
If your default working space in PS is set to sRGB, that doesn't mean that any image you open is sRGB!
Save for web can be set to retain all info.
Sorry?
Web galleries don't. Your browser does.
Use Firefox3.6 and set it to full color management.
That should not desaturate the image, unless they strip out the embedded .icc profile.
Again: That might affect the quality of the image, but not desaturate it.
Bingo.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
5,631 views & 0 likes for this thread
Latest registered member is oliverkell
1133 guests, 229 members online
