Thread started 21 Jun 2010 (Monday) 14:13
Adjusting areas selected by magic wand tool
sdipirro
Jun 21, 2010 14:13 |  #1
This is probably a very basic Photoshop question, but I couldn't remember how to do it and tried several things, none of which worked. I had a picture of a person standing on a white floor with a white background, and I was using a technique I've used in the past to blend the white floor and background to look seamless. Using the magic wand tool and holding the shift key, I select an area on the background and the floor. It did a good job selecting all around my subject EXCEPT for the white socks. Like half of the white socks on both feet were included in the selected area. I wanted to move the selection to the boundaries of the feet so they wouldn't be included, but nothing worked that I tried. I'm sure it's something simple! Thanks.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Bobster
Jun 21, 2010 14:15 |  #2
change the tolerance
Robert Whetton (external link) Dorset Portrait & Events Photographer | Photoshop Guru
Gear | Gram (external link) | Ultimate Lens MA FoCal 2 (external link)| Ultimate RAW Editor C1 (external link)
sdipirro
Jun 21, 2010 15:15 |  #3
What if the colors are almost exactly the same? Is there a way to manually adjust the selected area after it has been selected?
René ­ Damkot
Jun 21, 2010 16:34 |  #4
Hit "Q" for quick mask, then use an airbrush to add / subtract to the quick mask. When done, hit "Q" again.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
PixelMagic
Jun 21, 2010 16:41 |  #5
If you have person in white socks standing on a white floor why use the Lasso tool? The Color Range command or the Pen tool will give you a much better selection of the socks.
One option is to save the selection you've already made; use the pen tool to make a selection of the feet, then use the CTRL+Shift keys to combine the two selections.
2,590 views & 0 likes for this thread, 4 members have posted to it.
1698 guests, 139 members online
