Thread started 21 Jun 2010 (Monday) 14:29
Tripod head question
mchong75
Jun 21, 2010 14:29 |  #1
I’m embarrassed to ask this but, I need to know….
When a tripod head says it can “support” an XXX amount of weight, what is it exactly referring to?
I currently own a Manfrotto 055CXPRO03 3 Section carbon fiber tripod legs and a 322RC2 Grip Action ballhead which supports 11 lbs.
When I shoot macro with my 7D/battery grip and the 100L IS tilted for my shot, the ballhead losses grip.
Is this where the max weight “support” comes into?
(Michael) Gears:
5D MK III / Grip (2) | Canon 24-70L II | Canon 17-40L | Canon 70-200 f/2.8L IS Mark II | 600EX-RT (2) | ST-E3-RT | PCB Einstein (2) | Pocket Wizard Plus III (4) | PCB 47" Octobox | Vagabond Mini | Kacey Beauty dish | Lee ND, GND & Big Stopper | Lastolite 24" x 24" | Gitzo 3541LS tripod | Markins Q20 w/ RRS B2 LR II | Sigma 35 Art | 85L II
Jon
Joined Jun 2004
Jun 21, 2010 14:48 |  #2
Well, "support" is like a car's "MPG" - it's under ideal conditions. But it's actually worse than that, because there aren't any standards between manufacturers. So if you carefully balanced the load over the center of the ball head, yes, it could probably keep 11 lb. in place, as long as there weren't any outside forces acting on it. But with the load a bit off center, you run into other factors, like torque, that will give you the slipping you're seeing.
I'd suggest getting rid of the 322; it sounds like a better idea than it is in practice. Replace it with a solid ball head; a Manfrotto 498RC2 if you want to stay with the Manfrotto release plates or an Arca-Swiss-compatible head and RRS L plates if you're open to change (and willing to spend for it; RRS plates are very good, but not cheap).
Jon
Cocker Spaniels
mchong75
Jun 21, 2010 15:12 |  #3
Jon wrote in post #10401917 (external link)
Thank you
I guess it's time to upgrade the head. It's a great head but, I'm starting to see it's limits on what I need it for.
Thanks for the recommendation. Looks like 498RC2 has the extra weight support and the ability to do a 360 pan movement for my landscape shots.
(Michael) Gears:
mchong75
Jun 21, 2010 15:14 |  #4
Another question. I've been looking at RRS plates...
Are they compatible with battery grips?
(Michael) Gears:
mchong75
Jun 21, 2010 15:19 |  #5
I found the above answer from RRS site.
They are pricey!
(Michael) Gears:
Jonta
Jun 21, 2010 15:29 |  #6
mchong75 wrote in post #10402091 (external link)
They are pricey!
Hi. If you find the answer to a question you posed yourself, it is common courtesy to post the answer, so that others may benefit from your thread.
The answer in this case, is "yes".
Jon
Joined Jun 2004
Jun 21, 2010 18:59 |  #7
They are pricey!
Yes, but worth it.
Jon
Cocker Spaniels
josef2982
Joined Sep 2009
Jun 21, 2010 19:14 |  #8
Jon wrote in post #10403193 (external link)
Yes, but worth it.
what he said. they are absolutely worth it.. and will last a very very very long time (longer than the camera's lifespan anyway).
Canon EOS 6D | BG-E13 grip | 24-105 f/4L | 40 f/2.8 | Gitzo 0531 | Gitzo 1177M
mchong75
Jun 21, 2010 21:08 |  #9
Thanks. You guys sold me on it. It looks very stable and reliable.
(Michael) Gears:
954 views & 0 likes for this thread, 4 members have posted to it.
2806 guests, 167 members online
