Thread started 22 Jun 2010 (Tuesday) 09:37
Urgent Mac help needed - after LR3 install
hania
Jun 22, 2010 09:37 |  #1
imac
2.4GHz
300 Hdd
3 Ram
Lr3 was a disaster - I found it kept crashing my mac in 64 bit but limps alomng in 32 bit.
I mentioned on Lightroom forum that I had got 'kernel panic' after it crashed and (eventually) was advised to re-install Osx 10.5.8.
I did Time Machine backup & inserted disc.
Seemed to be ok in initially, but hung on ''importing documents' : it was ' approx time 19 hours and 56 min' overnight.
I pulled the plug & started again, imputting new admin name & passwork (which I wrote down); but now, it keeps saying my password is wrong - I can't even re-install as it wants the password.
I have only one use on (me) with standard priviledges - am at my wits end!
Tony-S
Jun 22, 2010 12:09 |  #2
I would reboot in safe mode and repair your boot disc permissions. If that doesn't help I'd boot from your install DVD and repair the disc. Also, kernel panics are usually tied to a hardware issue.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
mattyb240
Jun 22, 2010 12:25 |  #3
Yeah do a hardware check from the install disk and repair permissions. If this fails, run tech tool deluxe.
Deviant Art (external link)
hania
Jun 23, 2010 03:30 |  #4
mattyb240 wrote in post #10407190 (external link)
Thanks for that.
I have tried re-installing again - this time erasing the disc first - and am cautiously optimistic that all is ok.
Before, when I just re-installed, the re-install took about 2.5 hours; when I did erase & install, it took 35 mins!
Shall try the above if I am still having problems.
Admin priviledges seem ok; updating mac software currently.
Have managed to access and copy back some items from Tima Machine - which I couldn't do previously.
Am a bit concerned that I may have problems re-installing some software such as CS3 as I didnn't deregister it befiore erasing the disc.
Update: still getting ACL problems mainly on:
ACL found but not expected on system/library/UserTem​plate/Englist.lproj/ (lots of things,music etc)
also:
Just reinstalled my HP printer and am getting:
Groups differ////.... should be 80 are 20 which is a new one!
Update again: CS3 extended installed ok to my surprise.
Will have problems with Lightroom as lent the disc to my sister who lives in the US - so will have to wait until she sends it to me as LR2 /LR3 are upgrades .
MaxxuM
Jun 24, 2010 15:01 |  #5
Did you do the hardware checks (Disk Utilities > Verify Disk). It really sounds like you have a hardware problem. It's pretty clear you have corruption. I would check HD then move to RAM (use one model at a time to see if things improve).
hania
Jun 24, 2010 16:10 |  #6
MaxxuM wrote in post #10420433 (external link)
Yes did all that. Surprised its still there after a total clean reinstall of the system.
The HD disk verfies ok - never thought of checking the RAM - shall do that next.
mattyb240
Jun 24, 2010 17:20 |  #7
Yeah download techtool deluxe, it will test each component for you! And obviously make sure your all backed up!
hania
Jun 25, 2010 01:11 |  #8
mattyb240 wrote in post #10421148 (external link)
Its on the way - thought I could download it but looks like a disc is being sent.
hania
Jun 25, 2010 01:36 |  #9
I ran the Disk Utility from startup disk : HD checks out fine both in verify & repair.
Re Permissions: lots of problems - and now that I have re-installed itunes - permissions problems there both in verify & repair.
I may be being very dense, but I can't find where to check the RAM :) (the only options I have for checking are the HDD and any external drives I have)
mattyb240
Jun 25, 2010 02:00 |  #10
The main way to check the RAM is through the tech tool deluxe: https://support.apple.​com/techtooldeluxe/mai​n?id=dl (external link)
hania
Jun 25, 2010 03:14 |  #11
mattyb240 wrote in post #10423503 (external link)
I was just about to answer that I can't download this version because I am out of my 3 year aftercare package but just decided to double - check - and I'm just in time : August 2010!
Many thanks for reminding me of this .
hania
Jun 25, 2010 06:58 |  #12
All the system checks out clean, but still getting permissions problems. sigh!
Seeing as I am till just about in the 3 year care package do you think a trip to an Apple store is in order ?
TTk
Jun 25, 2010 07:02 |  #13
hania wrote in post #10424069 (external link)
Yes might be your best bet..:D
Terry.:cool:
http://www.terrykirton.co/ (external link)
http://www.ttkphotogra​phy.com/ (external link)
http://www.langtoftpho​tography.com/ (external link)
 (external link)
mattyb240
Jun 25, 2010 09:24 |  #14
Definitely take it to the store! Best to get any failings out the way before apple care runs out!
hania
Jun 26, 2010 02:02 |  #15
mattyb240 wrote in post #10424626 (external link)
I spoke to apple support over the phone - there is a file he pointed me to which lists all permission messages which can safely be ignored - those in red need to be urgently acted on.
All my messages fell into the 'ignorable' category - why do they bother to list them during repair/verify disc!
It does say ' permissions repaired' but then I had this long list - which left me unsure if they had actually been repaired or not....... .
The ACL messages are caused by files being moved from the library apparently.
Sigh ....so all this was almost for nothing..........but on the bright side, I have a clean install of the system.
2,610 views & 0 likes for this thread
Latest registered member is dsk26894
1195 guests, 338 members online
