Thread started 23 Jun 2010 (Wednesday) 13:42
Nissin Di622 modification for Canon
Tango_01
Jun 23, 2010 13:42 |  #1
Hello,
first post, I bought a Nissin Di622, 2 weeks later I found out that I wanted to do off camera lightning and I also bought 2 285Hv. My next step was to try to make the Nissin di622 work with my 285Hv setup, as you might know the Nissin doesn't work with radio triggers, so I found the youtube video posted on the strobist website. I called on of my tech's he did the mod, he solder the two wires on the tester button and we placed a socket(we got a stereo instead of a mono socket, so I'm not sure if this is the problem), we triggered it and it works but maybe 1 every 5 or 9 times we tried, took the cable out and it started firing which I guess tells me there is a short.
does anyone know a tutorial(not video) on how to do this modification? I have another friend that is going to look at the mod to see if there are any shorts of any kind.
any links would be helpful for him.
thanks.
Canon 40D |Canon 24-70mm F/2.8L | Canon 70-200mm F/2.8L | Canon 28-105mm F/4.5 USM | Canon 50mm F/1.8 | Canon 100-300mm F/4.5 |Vivitar 285Hv
Mark ­ Vuleta
Gallery: 48 photos
Jun 24, 2010 04:23 |  #2
Tango_01 wrote in post #10413747 (external link)
Hello,
first post,
...... My next step was to try to make the Nissin di622 work with my 285Hv setup, as you might know the Nissin doesn't work with radio triggers.......
Hello
Welcome to the site.
I'm a little confused, can you enlighten me as to why the Nissin flash wont fire with radio triggers?? I can't think of any reason.
Anyway, I cannot help with a video of the mod. but it is not difficult. However, it makes a lot of sense to use mono plugs & sockets (and the sockets without the tripping switch in them) Keep it simple is the best way to go.
vinmunoz
Gallery: 444 photos
Oct 09, 2010 12:38 |  #3
Maybe the trigger is not TTL that's why they modify.
| SONY A7SIII(2) | A73 | A6000 | Sony A7IV | Sigma105 | FE1635F4 | Tamron 70-180mm F2.8 | Tamron 17-28 Tamron 28-75 | FE50F1.8 | Sony 16035F4PZ | SEL30mm F3.5 Macro | Canon 24mm TSE | Laowa 15mm Shift
INSTAGRAM (external link)- WEBSITE (external link) - FACEBOOK (external link) - 500PX (external link)
richielee14
Joined Jul 2011
Aug 14, 2011 16:01 |  #4
Hello,
thanks.
Digging an old thread, but did you manage to solve this? I have the same problem where the flash fires when plugging in/out the cable. When it is fully plugged in, the flash actually freezes/crashes until I remove the cable (this is only when it is plugged to the trigger) if its just a cable with nothing plugged on the end, there it is still usable.
Any ideas?
6D Gripped - 14mm T3.1 - 35 f2.0 - 50 f1.8 - 24-105 f4 IS L - 70-200 f4 L
Website - www.richardlee.co.uk (external link)
yogestee
Aug 15, 2011 00:41 as a reply to  @ richielee14's post |  #5
Tango hasn't been back since his first post in June 2010..
Jurgen
klr.b
Aug 15, 2011 07:23 |  #6
richielee14 wrote in post #12934163 (external link)
Any ideas?
I don't have that flash, so I can't really help too much. All that mod is doing is shorting the connection to make the flash fire. When you're plugging it in (or unplugging), it's quite possible that you're bridging the connection for a split second. I wouldn't be surprised if it fired.
What you could do is find a hotshoe adapter that also has the same mini plug and attach that to the flash. Plug your trigger into the hotshoe adapter and see if it exhibits the same freezing.
gordon
Gear and Feedback
dedsen
Aug 15, 2011 08:55 |  #7
Are you using a stereo jack and cord? You need to use mono devices. The stereo stuff might keep the contacts shorted all the time if you have them plugged in just right.
klr.b
Aug 15, 2011 16:43 |  #8
klr.b wrote in post #12937666 (external link)
I just rethought what I wrote last night. This is what I'd do to troubleshoot a normal flash. I add the ports to eliminate the extra hot shoe adapter. However, this probably won't work on your Di622. That's the whole reason you did the mod in the first place, right? :oops:
gordon
Gear and Feedback
richielee14
Joined Jul 2011
Aug 17, 2011 04:10 |  #9
dedsen wrote in post #12938003 (external link)
Im not 100% sure, about the jack. Im sure I purchased a mono jack, but it doesn't feel right when I plug in a 3.5mm jack. It feels as though I need to force it in to plug in. I can use the same cable and plug it into another 3.5mm socket (iphone) and it goes in 'normally'. I will be off to buy another mono socket to see if this works.
3,723 views & 0 likes for this thread, 7 members have posted to it.
1800 guests, 122 members online
