Cant get the the PW to fire from the Sekonic. Any suggestinons? Tutorials anywhere?
promocop Member 223 posts Joined Mar 2010 More info | Jun 24, 2010 18:23 | #1 Cant get the the PW to fire from the Sekonic. Any suggestinons? Tutorials anywhere?
JKacey Goldmember 1,142 posts Likes: 3 Joined Jan 2007 More info | Jun 24, 2010 18:59 | #2 Verify your flash is set to manual and PW and meter are on the right channel.
That did it. I was on ETTL. Thanks. Now, how is it used practically !?
JKacey Goldmember 1,142 posts Likes: 3 Joined Jan 2007 More info | Jun 24, 2010 20:39 | #4 promocop wrote in post #10421659 That did it. I was on ETTL. Thanks. Now, how is it used practically !? You are asking how a light meter can be used practically when shooting in a manual mode?
When trigeering strobes
Jun 24, 2010 21:17 | #6 promocop wrote in post #10422189 When trigeering strobes You use it when you want to meter the lights. you just hit the button on your light meter to get a meter reading off the strobes instead of having to use a sync cord. Jerome
Right. Got that. Now. If you need to adjust the output of the strobe can it be done on the 5d or on the 580? I also notice that the Sekonic will give a % of light from the strobe vis a viz the total overall exposure
Jun 24, 2010 23:08 | #8 promocop wrote in post #10422871 Right. Got that. Now. If you need to adjust the output of the strobe can it be done on the 5d or on the 580? I also notice that the Sekonic will give a % of light from the strobe vis a viz the total overall exposure No, you cannot adjust the output in camera. Jerome
So unlike when the strobe is teathered via a cord if you can't adjust on the fly one has to manually adjust on the unit? If that's the case then I guess one has to guess at the original exposure take the reading and then go to where the flash resides and adjust accordingly? Seems rather clumsy!
| Latest registered member is johntmyers418 1036 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
