@Chris: Thanks for the info. I've looked at photos taken with both, and you're right... there's definitely something different about the way the El Octa spreads its light. I was thinking about moving anyways so at least I have a good Plan B already!
@TMR Design: Thanks for measuring the stats on the 53". You're right, not much leeway to angle with, unless the subject is lying on the floor...but it gives me hope! I just tried modeling El Octa in google sketchpad...looks doable if I can just find a low enough height stand (see attached image).
Hmnnn...if i buy it and can't get the angles I need I suppose i'll just have to move after all.
Anyone using the Octa with 8' ceilings currently and have pictures of their setup they can share?
Thanks everyone!
