FORUMS Photography Talk by Genre Nature & Landscapes Talk
Thread started 26 Jun 2010 (Saturday) 07:53
AF/MF on panorama?
Kaksa
Joined Jun 2010
Jun 26, 2010 07:53 |  #1
What's the best when taken multiple photos for Panorama?
Should I use autofocus and focus between every shot, or is MF better, so the focus is at the same place at each picture?
Untill now I have used AF, but what do you use?
Edit: typo...
-Kim- (external link)
jrader
Jun 26, 2010 11:36 |  #2
Find the closest object in the entire panorama. Choose an aperture. Set the focus manually to the hyperfocal distance. Shoot away.
John
www.GreatEscapePhotogr​aphy.com (external link)
Facebook Page (external link)
Instagram: @greatescapephotograph​y (external link)
goldboughtrue
Jun 28, 2010 18:53 |  #3
Definitely manual focus so the camera doesn't choose a close object on one side and a far object on the other side.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
joayne
Jun 28, 2010 18:55 |  #4
Manual Focus..TriPod.. Constant Aperture
joayne Contribute to POTN | Worldwide Photo Week
Please Quote the post to which you are responding.
BobL
Jun 29, 2010 21:34 |  #5
joayne wrote in post #10443314 (external link)
Strictly speaking a standard tripod does not locate the camera in the correct geometrical placement for a panorama. The camera needs to rotate about the nodal point of the lens which is usually somewhere between the front of the lens and the sensor and the point differs for each focal length used. This is generally only an issue for when some objects are near and some are distance in the same scene eg indoors, once all the objects are more than 10 metres away this is less significant.
If you require a level horizon, the head and camera need to be level, and if you want to get accurate alignment of images with near and far components a nodal placement tripod head is necessary.
Even though I have a manfrotto pano tripod head that allows me to set the camera level and the rotation point correctly, I shoot most of my panos handheld, on auto focus and auto exposure.
Sometimes I do set out with all the photo accessories and the kitchen sink and allocate the time to get a good pano but more often that not I take the opportunity to quickly capture a passing pano in the brief moment I am there. However, I reckon it's still worth knowing how to take them hand held - at least keep the camera in the same approximate spot and rotate your body around the camera instead of the other way around. OK - I still get exposure banding, wonky horizons, and stuff doesn't line up etc but capturing the scene is often more important than accuracy and lugging photo gear around and managing an exponentially increasing number of images. Often I stitch the images together and don't bother cropping out the final image, like the attachment of the woodworking shop below. I took that standing in the busy doorway of the woodworking shop -If I had turned up with a big tripod and cluttered up the door way I probably would have been asked to move
These were shot with a Pano tripod head manual exposure manual focus.
With some panos like the pool shot above that include shots into the light I also extensively bracket and pick the best shots to include in the pano.
This was done with a monopod - this is good because at least you can rotate about it.
And the rest (and most of the zillion of others taken in the last 36 years) were all hand held auto focus and exp
2,403 views & 0 likes for this thread
AF/MF on panorama?
Latest registered member is CynthiaBoyle
925 guests, 302 members online
