when i view shooting information and at the top where it says file name along side there it says 54654.CR2 is this the total number of shots taken with my 40D this in DPP Software...............
lippy113 Senior Member 498 posts Joined May 2006 Location: Dorset UK More info | Jun 27, 2010 06:44 | #1 when i view shooting information and at the top where it says file name along side there it says 54654.CR2 is this the total number of shots taken with my 40D this in DPP Software...............
Jun 27, 2010 07:37 | #2 No. In almost all cases the filename bears no relation to the shutter count - because the sequence can easily be reset to a higher number by using a CF card that has been use din a different camera. EOSInfo Frank Hollis - Retired mass spectroscopist
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Jun 27, 2010 08:04 | #3 It could have something to do with your shutter count. Mine says 597Y6640.CR2 and my camera body has 6640 shots on it and I use different cards in mine and it doesn't change it at all. Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
TeamSpeed 01010100 01010011 More info | Jun 27, 2010 08:09 | #4 Saint728 wrote in post #10434128 It could have something to do with your shutter count. Mine says 597Y6640.CR2 and my camera body has 6640 shots on it and I use different cards in mine and it doesn't change it at all. Take Care, Cheers, Patrick If it does match, it is coincidence. As has been proven through the years, the filename is not the shutter count. You can reset the filename in the menu, as well as change the filenames by putting in cards that have higher named files. Past Equipment | My Personal Gallery
hpulley Goldmember 4,390 posts Joined Oct 2009 More info | Jun 27, 2010 08:35 | #5 If you have under 9999 shots and have never reformatted your card or shared cards with another camera then it may well be your true shutter count but with a 40D get the EOSinfo program, it will show you the actual shutter count. flickr
| Latest registered member is johntmyers418 1219 guests, 187 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
