Does it only specifically shoot only in ettl? do they shoot in manual as well? thanks in advance!
jayseersts Member ![]() 199 posts Joined Jan 2010 More info | Jun 29, 2010 00:57 | #1 Does it only specifically shoot only in ettl? do they shoot in manual as well? thanks in advance! CANON 5D MARK II GRIPPED/35 1.4 L/2X AB800/CYBERSYNCS
ELT_Photo Senior Member 301 posts Joined Jan 2008 Location: Royal Oak, MI More info | Jun 29, 2010 01:07 | #2 Yes, the mini/flex system can also be used as manual (dumb) triggers, also in combination with PW Plus II, Plus, and MultiMax units. Passion - Dedication - Inspiration (and some gear)
scata Member ![]() 47 posts Likes: 4 Joined Apr 2007 Location: Romania, Bucharest More info | but the PW Plus II can trigger the tt1 as a remote?from what I know Flex tt5 cant trigger the tt1 as a remote. Canon 5D MARK III, 70-200/@.8 IS IIL IS, 17-40L, 100/2.8 Macro, Canon 35mmL,CANON 135mm f/2.0
Headshotzx Goldmember ![]() 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Jun 29, 2010 03:38 | #4 |
Cham_001 Senior Member ![]() 880 posts Likes: 58 Joined Feb 2009 Location: based between Ruse, Bulgaria & Recife-Brazil More info | Jun 29, 2010 10:57 | #5 Headshotzx wrote in post #10445830 ![]() TT1 = transmitter TT5 / Plus II / Multimax = Auto sensing transceivers TT1 can trigger both TT5 and Plus II and Multimax but cannot be triggered by others. +1 "... with a clear perspective - the confusion is clearer ..."
dmward Cream of the Crop More info | Jun 29, 2010 11:17 | #6 The Control TL system permits you to combine ETTL and manual. David | Sharing my Insights, Knowledge & Experience
Olar Member ![]() 36 posts Joined Mar 2007 Location: Southern Ontario, Canada More info | Jun 29, 2010 11:28 | #7 ...........and with your 580EX II on the transmitters (mini or TT5) top shoe you can control the manual output level of each remote speedlite. Note that this feature is only available when using the 580EX II. Original 580EX will not do it. Canon 7D, 40D, 1 - "L", 1 - almost L, 3 - primes, 3 speedlites, PW's and L358.
dmward Cream of the Crop More info | Jun 29, 2010 11:35 | #8 Right Olar, David | Sharing my Insights, Knowledge & Experience
alright thanks about to pull the trigger on them a plusII, a mine and 2 flexes, im running one ab800 off the plusII and the flexes on my speedlites. thanks to all for the help. CANON 5D MARK II GRIPPED/35 1.4 L/2X AB800/CYBERSYNCS
ericski Member 166 posts Likes: 5 Joined Sep 2009 Location: Boise, Idaho More info | Jun 29, 2010 14:13 | #10 Eventually (as in PW is saying sometime this summer) there will be the AC9 adapter for flexes that when coupled with the (as yet unreleased) AC3 will allow remote power control of your AB800.
rang Goldmember 1,644 posts Likes: 6 Joined Jan 2007 More info | Jun 29, 2010 17:35 | #11 jayseersts wrote in post #10448229 ![]() alright thanks about to pull the trigger on them a plusII, a mine and 2 flexes, im running one ab800 off the plusII and the flexes on my speedlites. thanks to all for the help. Before you pull that trigger...check and make sure the PW's don't still have RF issues with the majority of Canon Flashes. They did when I had to decide and the PW solution was a sock to cover the flash and then later a special mount to shield them. Lotsa stuff, running outta room and a wife...I keep looking at her and wondering???
dmward Cream of the Crop More info | Jun 29, 2010 20:27 | #12 I use a FlexTT5 to fire my monolights. David | Sharing my Insights, Knowledge & Experience
mikekelley "Meow! Bark! Honk! Hiss! Grrr! Tweet!" ![]() 7,317 posts Likes: 16 Joined Feb 2009 Location: Los Angeles, CA More info | Jun 30, 2010 02:31 | #13 Don't forget hypersync with your bees. pretty awesome Los Angeles-Based Architectural, Interior, And Luxury Real Estate Photography
jdfotos Member 118 posts Joined Sep 2009 Location: Buckinghamshire More info | Sorry if this is a stupid question....but does HSS work when using a speedlite (580exii) in manual mode?? I know it does in ttl but I cant find confirmation about in manual. Thanks. EOS 7D Gripped / EOS 400D Gripped / 17-40L F4 / 70-200L IS USM F2.8 / Sigma 24-70 2.8 HSM / 50mm F1.8 / 580EXii / Some other flash stuff
dmward Cream of the Crop More info | Jun 30, 2010 08:46 | #15 Like a charm. David | Sharing my Insights, Knowledge & Experience
y 1600 |
Log in Not a member yet?
Latest registered member is JTravLog 694 guests, 113 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
