Thread started 29 Jun 2010 (Tuesday) 16:37
CISS leak through ink head.
czynot
Jun 29, 2010 16:37 |  #1
I have CIS system in all my epson printers. I have no problem with the R580. But after installing the CIS in the epson 2200 printer, I installed the air filters on the tank. I notice BLACK ink drips or runs on paper while printing. There are also drops of in on the inside of the printer. The ink cartridge is sitting tight. Ink tank is sitting same level ask printer (same table). Look like the ink is coming through the print head.
I notice air bubbles on all the ink lines. The air bubble will move if I move the ink tank high or lower than the ink cartridge. I bleeded the air out of all the cartridges and still only the black ink leaks while printing. No leak or drips from cartridge after removing cartridge from printer.
I replaced the original inks and it is fine. no drips anywhere.
I read leaks are problem for CIS but didnt have this problem with R580. Is this due to air in the line? bad black cartridge? Should i get rid of CIS system and get refillable cartridges?
5D MKII, 24-70mm L, 18-55mm IS,70-200mm 2.8L IS, 50mm 1.8, 100mm Macro, 2-580EX
czynot
Jun 30, 2010 08:00 |  #2
I got it figured out. After 2 days of trying. my hands and trash can turn into rainbow color. I found out that it was the air in the lines. After bleeding every bubble out of the cartridges. the drips stop and no ink runs onto paper.
BillwYellowstone
Jul 22, 2010 21:15 as a reply to  @ czynot's post |  #3
Just got a 2200 from a friend, considering the CIS but concerned about the heads lasting. I had tried refilling carts a long time ago, but had issues and a ruined printer when the print heads leaked. What is the long term use like?
Bill W Yellowstone NP Old Faithful
Gripped Canon 5DMklll 24-105 Rokinon 14mm 2.8 Tamrom 150-600
Here for the Winter!
6,450 views & 0 likes for this thread
Latest registered member is oliverkell
1141 guests, 219 members online
