Thread started 30 Jun 2010 (Wednesday) 16:23
Think Tank Airport International v2 of Takeoff?
ZCphoto
Jun 30, 2010 16:23 |  #1
I'm trying to decide which one would be better for travel. The major difference, to me, is the backpack capability. Anyone have experience with both? I'd like some advice.
Robert
5D MKII I 1D MKIII I 7D I G11 I S90gear list sales feedback
NicolasRubio
Jun 30, 2010 17:37 |  #2
What gear do you own?
I have the Takeoff, so I may be able to help you out!
Gripped 7D - 3 Ls - 3 non-Ls - 580EX II - Too much Think Tank gear - Cotton Carrier Holster
Detailed Gear List - My Website (external link)
ZCphoto
Jun 30, 2010 17:51 |  #3
NicolasRubio wrote in post #10455817 (external link)
Most trips will be with two bodies and 5-6 lenses (all L's but currently nothing longer than 70-200), a 580EX, gitzo travel tripod, 15" laptop and an ipad. Probably a few other things like my videocan, mic, etc. I will eventually pick up a 300 2.8 (replacing a 120-300), which may come along. I doubt I'll ever have anything larger than a 300 but I would love to be able to pack my gitzo 1541T in the bag.
Robert
NicolasRubio
Jun 30, 2010 19:03 |  #4
ZCphoto wrote in post #10455881 (external link)
I don't know if all that gear would even fit in an Airport Security V2.0. The problem is the tripod INSIDE the bag, because if not, I think that it'd fit in all three of them.
Lets see, in the Airport Takeoff:
1D Mark III -> CHECK
(Ungripped?) 5D Mark II -> CHECK
70-200 (Which one) -> CHECK
300 2.8 -> CHECK
580EX -> CHECK
15" Laptop -> CHECK
iPad -> Most Probably
Gitzo 1541T -> Only in the outside, with the included tripod holder
Headshotzx
Jul 01, 2010 00:41 |  #5
A 300 2.8 should be packed vertical and not horizontal in the TakeOff, so that alone would take up about 40% of the bag.
If you have two cameras with grips, consider one full-length deep-space portion gone (in photo: D3 and the two spaces on the left).
A 70-200 with hood reversed will take up the space of about three 85Ls, so you'll be left with only enough space for a single 85L and the upper 15% portion of the bag (which is deep enough only for the height of an ungripped camera) to store your other stuff.
TTP Photo:
IMAGE: http://www.thinktankphoto.com/product-images/xlarge/Feature-Airport-Takeoff-5.jpg
If you're gonna be shooting with ALL your gear, consider the think tank airport security instead. If lets say you're taking your zooms + 300 2.8 only, the International would be a better choice.
Zexun | Flickr (external link) | YouTube (external link) |
ZCphoto
Jul 01, 2010 12:39 |  #6
Here's what will be in the bag for an upcoming trip:
5D MKII ungripped
T2i
videocam
S90
16-35
Zeiss 21
24-70
24L
70-200 2.8
15" laptop
iPad
chargers, lenspen, rocketblower, CF/SD cardholder, etc.
Robert
Headshotzx
Jul 01, 2010 12:55 |  #7
My preference for trips is a backpack. But if you must have a roller, a roller backpack would work too.
Your gear will fit into the takeoff no problemo.
NicolasRubio
Jul 01, 2010 14:31 |  #8
ZCphoto wrote in post #10460739 (external link)
5D MKII ungripped
T2i
videocam
S90
16-35
Zeiss 21
24-70
24L
70-200 2.8
15" laptop
iPad
That will fit in the Airport Takeoff with no effort at all! If you have any further questions on the bag, or need pics, shoot me a PM!
PS: remember my affiliate code? :D http://www.thinktankph​oto.com/affiliates.asp​x?code=AP-427 (external link)
hfgarris
Jul 01, 2010 14:52 |  #9
I have had both and still have the Airport International (sold the Takeoff brand-new recently as I am trying to fund a long/fast lens $$$$ ... otherwise would have kept it!).
They are very similar although the Takeoff has slightly less depth due to the backpack straps, the external dimensions are the same. The Takeoff has a covered laptop pocket rather than just a elastic sleeve, but in doing so loses the front zipper compartment of the International. However, if you buy the low-divider set for the International for better laptop storage, but find the Takeoff laptop pocket adequate ... then you will have MORE resulting depth in the bag with the Takeoff (confused??).
The zipper locking is different as the Takeoff doesn't have the fixed lock bracket and also doesn't have the lock-down cable on the back (both have the laptop cable lock in front). The notched-dividers allow camera with lens at the top and down the deeper side of the Takeoff, good for gripped/pro bodies.
The Takeoff is slightly lighter in weight and the dividers don't seem as thick.
Both are excellent bags and you can't go wrong with either of them (or any Think Tank bag)!
hope that helps some,
-howard
Here is my Airport International loaded up:
https://photography-on-the.net …?p=8879796&post​count=2523
NicolasRubio
Jul 01, 2010 15:46 |  #10
hfgarris wrote in post #10461662 (external link)
Very :confused:
Could you explain that again, please?
hfgarris
Jul 01, 2010 16:48 |  #11
NicolasRubio wrote in post #10461967 (external link)
Very :confused:
Sorry for the poorly thought out sentence...:o:cool:
The main reason I thought I wanted the Takeoff when I already had the International wasn't because of the backpack capability (I don't like backpacks!).
I wasn't too comfortable with my laptop in the stretchy pouch on the International when traveling, so I purchased the low divider set to allow the laptop to be carried inside the bag. The Takeoff has a covered pouch on the front for your laptop with the security of a clip to keep it closed which would prevent someone from grabbing your laptop and running off with it as you walk through an airport (although they both have a cable lock if you use it).
So, when comparing the International with low dividers with laptop inside the bag, against the Takeoff with full dividers and the laptop in the outside pocket, the Takeoff will have more depth for lenses as configured for my use, even though the stock International is deeper.
This would have allowed me to stand some lenses on-end which were laying down in my old bag, giving me a bit more room in the bag for another lens or two.
So there...  :p:cool::lol:
-howard
NicolasRubio
Jul 01, 2010 19:57 |  #12
hfgarris wrote in post #10462282 (external link)
-howard
Oh, now I get it! :D
What about the Airport Security V2.0 with low dividers? Too big?
hfgarris
Jul 01, 2010 21:20 |  #13
NicolasRubio wrote in post #10463152 (external link)
Yeah ... too big ...
I didn't want to be challanged at the gate about carry-on size, whether international or domestic flights. I have been asked to "gate check" the Airport International on a couple of occasions even though I was sure it would have fit in the overhead bin (they did that for anyone with a wheeled bag). Usually the TT International flies thru check-in without any problems!:D:cool:
-howard
ZCphoto
Jul 01, 2010 21:52 |  #14
Yes I definitely want to have a hassle free flight. Last week I was forced (at gunpoint........kiddin​g) to check in a small Oakley roller case so it made me think. I had a Tilopa but sold it due to concern about size. Now I realize the removable internal unit would have come in real handy if I had gear with me. I'm thinking the backpack look of the bag may help bringing it on board.
Robert
hfgarris
Jul 02, 2010 12:49 |  #15
ZCphoto wrote in post #10463703 (external link)
As I have observed, plus reading experiences of others on the forums, it seems that people wearing backpacks are rarely challenged at the check-in counter, or at the gate, with the size issues of their carry-on bag. However, even roller bags which fit the sizing-frame at the counter, may not be allowed in the cabin by the gate attendants when the flight is full.
They seem to use "wheels" as the determining criteria of who is asked to gate-check the bag and who gets to carry it onboard. As such, the "Takeoff" may offer some advantage if you become aware that they are restricting carry-ons, and you can convert the bag to the backpack configuration before they single you out for a gate-check-tag.
-howard
13,258 views & 0 likes for this thread, 7 members have posted to it.
2527 guests, 170 members online
