POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 01 Jul 2010 (Thursday) 21:46
LR3 - not import movies?
viodea
Joined Feb 2006
Jul 01, 2010 21:46 |  #1
Is there any setting in LR3 to ignore certain file type when import?
I store my movies on a different directory and I don't want them to mix with picture files.
JayWarner
Jul 01, 2010 21:54 |  #2
Without scanning the Import display: The Import command can get fairly narrow in selection of folders, etc. Don't tell it where the movies are :)
viodea
Joined Feb 2006
Jul 01, 2010 22:56 |  #3
The movies & pictures are in the same folder on my memory card.
tonylong
...winded
Gallery: 60 photos
Jul 02, 2010 01:33 |  #4
Well, you can either Import them with your other photos then select and remove them (quick) or you can deselect them from your Import dialog -- they'll still be on the card and you can copy/move them to the directory of your choice. I don't think there is a "smart ignore" of supported file types when importing...other than the ignore duplicates and the option to not treat jpegs as separate from Raws.
Tony
tzalman
Fatal attraction.
Jul 02, 2010 01:35 |  #5
Uncheck the video files - the small check box in the upper left corner of each thumbnail.
Elie / אלי
viodea
Joined Feb 2006
Jul 03, 2010 00:14 |  #6
I understand you can uncheck file I don't want to import but with hundreds of file, it's hard to un-check all videos. It would be much easier if I can sort by file type on the import dialog. Of course, configurable file type will be best. It's trivial to add such support. I can't believe it's not there in the first place.
NinetyEight
"Banned for life"
Jul 03, 2010 04:20 |  #7
Move them before importing the images into LR?
Kev
In2Photos
Jul 03, 2010 14:21 as a reply to  @ NinetyEight's post |  #8
That would seem like a huge oversight on Adobe's part to not include some sort of filter. :confused:
Current Gear and Feedback
PixelMagic
Jul 03, 2010 17:25 |  #9
Two ideas to try....I've never imported video into Lightroom so I don't know if either will work but it wouldn't hurt to try.
1. Create an Import Preset. Plug in your camera; uncheck the video files, then save the setting as a Preset. If you look at the lower middle of the Import dialog box you will see a drop-down box to save Import Presets.
2. Use the Sort function. Sort by File Name then uncheck the movie/video files.
tonylong
...winded
Gallery: 60 photos
Jul 03, 2010 19:43 |  #10
Since my LR3 Beta has expired and I can't see the new Import interface, I'm taking a stab here: in the interface (before opening the actual dialog) when you select the card, doesn't a grid with the images open up? And can't you select a Sort order, like you do with the normal grid? If so, you can sort by file type and quickly select the CR2s to import and leave the video files alone, right?
I may be mistaken, though, about the interface, in which case you should ignore me. But please don't put me on your Ignore list, or I may feel sad and lonely...
Tony
viodea
Joined Feb 2006
Jul 06, 2010 00:14 |  #11
I can sort files by name or capture date but not by file type. sad... sad... sad....
I'll try the import preset idea and see if that works.
Copy & delete movies first before import image works. I would rather do a format card instead of delete movies then format card.
I wish they support AVCHD. If they do, I can just use lightroom for all my digital media instead of lightroom for pictures then something else for movies.
obkcaptain
Jul 06, 2010 01:36 |  #12
Viodea:
Sorry, wich kind of system are you working with?.
Sincerely, I prefer download the memory card in a folder on my PC. Then sort the files an finally to making a sub folder for the pictures. When in LR, I import ONLY pictures
A Canon gear, some lenses, mono(tri)pod, flash and need to learn...
viodea
Joined Feb 2006
Jul 07, 2010 22:52 |  #13
I'm using mac.
2,870 views & 0 likes for this thread, 8 members have posted to it.
2216 guests, 124 members online
