Thread started 03 Jul 2010 (Saturday) 14:19
How to clean behind focus screen
willjameson
Jul 03, 2010 14:19 |  #1
Ok folks, I need some advice... I changed my focusing screen, and in the few seconds it took to do so, about 2 thousand little specks of dust got onto the glass behind it. Any suggestions as to the best way (not sending it out, they want $150 and 2 weeks) to clean it. Thought about using lens cleaner but not sure what type of (if any) coating is on that glass, and the rocket blower does nothing to help.
Suggestions??? Please??
Primary Body: 5DMk2
Lenses: 17-40L, 70-200F4L, EF 100mm f/2.8 Macro, 70-300IS USM, 28-135IS, 70-200F2.8ISL
Delija
Jul 03, 2010 15:26 |  #2
Two weeks and $150 seems insane!
Maybe you can find a camera shop with a competent camera tech - local guy here charges $40 to clean sensor and focus screen while you wait.
This isn't the weekend to find anyone, but the dust shouldn't affect your images as long as it's not on the sensor (I'm not sure what glass you mean by "behind the focusing screen").
Good luck,
D.
Wow, what a nice picture! You must have a really great camera!
Mark1
Jul 03, 2010 15:39 |  #3
Ill do it for $75 and only take one week!!!
Ill just flip the lever so the screen falls down and blow it out with a rocket blower, push it back up and mail it back!!!
Sound good to you?
But really it is that easy.
willjameson
Jul 03, 2010 16:55 |  #4
Unfortunately, there's no one in florida that I've been able to find who does anything like that. There's only one shop in my county and they won't do anything. when you flip down the focus screen, the glass behind (under, whatever word you like to use) that has the focus points etched on it. No, it doesn't affect the images, but man is it annoying. There's also the back-of-the-brain thought of having a $2500 camera with tons of dust in the view finder.
Delija wrote in post #10472253 (external link)
Good luck,
D.
Primary Body: 5DMk2
willjameson
Jul 03, 2010 16:57 |  #5
I wish it were that easy. The rocket blower does nothing. I've pumped that thing in there so many times that I've given myself carpal tunnel. I tried brushing it with the little brush that came with my cleaning kit and it just made it worse.
Mark1 wrote in post #10472308 (external link)
Sound good to you?
Primary Body: 5DMk2
Saint728
Jul 03, 2010 17:21 |  #6
Try this out before you send it off or worse yet try to take out the pentaprism to clean. http://www.ascent-design.com/photo/Clean​5D/ (external link)
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
lannes
Jul 03, 2010 19:36 as a reply to  @ Saint728's post |  #7
I've cleaned the superimpose (SI) screen a few times, it's quite easy, but frustrating.
Never dry clean it, as this will scratch the delicate surface and this will show up as streaks in the view finder. I use visible dust sensor clear and a swab once to remove the dust, from both sides of the SI screen and the bottom of the pentaprism block.
A tip is not to take a short cut and use a blower on the SI screen while it's in the camera, the dust can be blown through the copper shims, around the SI screen and onto the pentaprism block which will then also need to be cleaned. Also make sure you remember which way the SI screen came out otherwise you'll loose the red AF focusing lights.
Here is another process from Shimworld
http://shimworld.wordp​ress.com …-the-5d-mk-ii-viewfinder/ (external link)
willjameson
Jul 03, 2010 19:59 |  #8
Thanks everyone for the instructions!! They really do 'look' easy. Now, my next question...is it worth attempting this, or realistically should I not take the chance and just live with the dust? I guess my question is, is it really as easy as it appears, or am I risking making things a whole lot worse just because of aesthetics?
Primary Body: 5DMk2
lannes
Jul 03, 2010 20:17 as a reply to  @ willjameson's post |  #9
It's easy, but you need to be meticilous and extremely careful, you need to have all the right tools and cleaners and a clean, well lit and relatively dustless area before you start before you start. I recommend using jewellery screw drivers and tweezers to remove the screws and to lift up the metal tabs slightly.
The big issues are scratching the SI screen and loosing the tiny screws holding the metal plate. If the small screws fall into the mirror box, it's a trip to canon to get them out. The screws are also hard to get back in without a magentised screw driver or pointed tweezers to lay them in the screw holes.
Also the copper shims are fragile and bend very easily. Getting them and the SI screen to seat back in also requires some patience as there are cutouts and tabs that need to be aligned.
Take note of the order and orientation of what came out of the mirror box so you can replace it the same way.
Try not to damage the foam edges on the metal plate as later on these could cause problems in the mirror sealing and dampening.
Also swabbing the screen and pentaprism can push the dust into the corners without actually removing it, I had success with the Artic butterfly to get the last bits out after it has dried.
When your ready to reassemble hold the camera up to a bright light source to see if there are any more dust particles left. If they are in focus then they are on the SI screen or pentaprism block, usually out of focus means focusing screen or mirror.
Give everthing your putting back in a blow with a blower on both sides before reassembling.
Good luck
ChrisMc73
Jul 04, 2010 08:45 |  #10
So I've had this same question for a few days since I stupidly allowed a friend photographer talk me into swapping out a focusing screen with crop marks that he had, with mine, so I could shoot a family and keep them in the crop lines for a canvas wrap print.
His intentions were good, but I probably didn't need the screen swap for what I was doing.
Anyway, since then, the dust has been bugging me, I've removed the focusing screen and used my rocket blower down in the camera and on the focusing screen as well. Didn't help. I have even used a lens cloth on the focusing screen too, sometimes made it worse, sometimes helped but not 100%, I'm wondering after reading some of these posts and links, if I've ruined the focusing screen now? Is it that sensitive that I can't/shouldn't touch it with a lens cloth?
It doesn't appear that I've done anything, when looking through it, other than move dust parts around. Can I squirt some lens cleaning solution on this thing and wipe or swab it to try to remove the dust particles? Or should I just take it into a camera shop now and have the entire process cleaned (sensor, mirror, focusing screen), the works?
Ianfp
Jul 04, 2010 09:57 |  #11
I had the same problem and ended up buying a new focus superimpose screen. If you can find a Canon parts seller, it is worth buying a spare before attempting to clean the existing one. They are quite cheap - approx $10 to $20.
I would say that although quite a straightforward job, it is very difficult to remove every speck of dust. The two small screws are quite fiddly too!
Ian
Nikon D850, 85mm f/1.4G
5D2
EF17-40 f/4.0 L, EF135 f/2.0L EF200 f/2.8L
EF24-105L, EF100 f/2.8L Macro. EOS-M, 22mm f/2
Hasselblad 500C/M, Planar 80mm f/2.8
ChrisMc73
Jul 04, 2010 10:04 |  #12
Ianfp wrote in post #10475321 (external link)
Ok, wait, is there a difference in the SI (Super Impose) screen and the Focusing Screen? How do you know which one is the one with the dirt?
I just swapped out my focus screen and now I have the dirt particles, but did I end up getting both SI and FS dirty doing this?
I will look for a local Canon parts seller, but B&H has been my source for all my equipment, online, and the cheapest, no tax for me through them. If I have to use them for this its $30.
For the 5D Mark II, I guess this is the one?
http://www.bhphotovide​o.com …dard_Precision_​Matte.html (external link)
Why are they so hard to clean?
willjameson
Jul 04, 2010 10:42 |  #13
Ok everyone.. I'm going to attempt to clean the SI screen. Wish me luck
Primary Body: 5DMk2
willjameson
Jul 04, 2010 15:25 |  #14
Ok, four hours later and I'm done. It really wasn't that difficult, but I took way more time than I think I needed to. It's still not perfect, but MUCH better than it was. Thanks to all for the advice.
Primary Body: 5DMk2
EL_PIC
Jul 04, 2010 17:21 |  #15
willjameson wrote in post #10472053 (external link)
and ....
There is something rotten in Florida if
1. you got 2,000 specs in a few seconds
and
2. it took you 4 hours to clean
EL_PIC - RIT BS Photo '78 - Photomask Engineering Mgr
Canon DSLR - Nikon SLR - Phase One 60MP MFDSLR
http://www.Photo-Image-Creations.com (external link)
http://www.musecube.co​m/el_pic/ (external link)
http://www.facebook.co​m/PhotoImageCreations (external link)
12,687 views & 0 likes for this thread
Latest registered member is Ivy Yeh
647 guests, 248 members online
