Thread started 05 Jul 2010 (Monday) 01:17
Wireless monitor and transmitter for $190
bunyarra
Gallery: 6 photos
Joined Feb 2006
Jul 05, 2010 01:17 |  #1
Now, this DOES look interesting. Still a bit heath-robinson in looks but if it works, full credit to Robert.
http://robertbenson.co​m …ss-dslr-external-monitor/ (external link)
-range for the monitor is up to about 30 feet or more, a bit less depending on what’s in the way.
-the transmitter will send the video or still photo feed wirelessly to one or more monitors.
-transmitter and receiver run off a 9-volt battery; monitor is rechargeable and runs 2-3 hours continuously. Draw on the nine volt battery is minimal: the transmitter draws only 70mA.
-transmitter has a 3.5mm stereo miniphone connector to go into cameras with A/V out, like the Canon 5dmk2. It uses a mono 3.5mm miniphone input for cameras like the Canon mk2, Mk3, etc, which have a video out (as opposed to A/V out, which is usually a stereo connection). Specify camera when ordering.
-works with video liveview in preview or record mode. No delays.
-transmitter attaches to camera strap via a clip.
-receiver unit and battery pack is built onto the back of the monitor and has on/off switch.
-color monitor is seven inches and displays standard definition, 480p. Monitor can be used for watching TV if you’re not using as a photography monitor. It’s sleek and lightweight; no visible antenna.
-monitor – in most cases – has a standard size, 1/4″ threaded base for mounting to stand, tripod, Bogen Magic Arm or various Red Rock-type hardware.
Michael Gove
http://photosignals.sm​ugmug.com (external link)
Google+ Profile (external link)
photopat
Jul 05, 2010 15:15 |  #2
You have the Pixel LV-W1 at around $360 that has also a build in remote control
http://www.pixelhk.com​/en/proview.asp?P_ID=1​543 (external link)
toys list
974 views & 0 likes for this thread, 2 members have posted to it.
1637 guests, 140 members online
