Mike787 wrote in post #10480959
Ok, sorry for all the questions, but what size should I get? What do those focal lengths denote?
Focal length isn't an issue except for determining if a filter will cause vignetting (darkening of the corners). The thicker the filter, or the farther out the holder protrudes, the sooner it'll vignette. This is why companies like B+W make slim filters and Lee makes a wide angle adapter ring. This is usually only a problem when you get very wide, like under 20mm on a full frame.
The other number is the diameter of your lens' filter threads. This could be a number like 58mm, 72mm, 77mm, etc. You can put a 77mm filter on a 58mm lens with an adapter but you can't do the reverse without severe vignetting. Step up rings will prevent you from using a hood though.
