Tell, please, interior width F-803. On a site bhphotovideo
the width - 4, and on a site tiffen
- 3.
phgraf Hatchling 7 posts Joined Jul 2010 More info | Jul 07, 2010 13:09 | #1 Tell, please, interior width F-803. On a site bhphotovideo
renzir Hatchling 6 posts Joined Jul 2009 More info | Jul 07, 2010 16:56 | #2 Its flexible so not so easy to measure (my bag is also not here now). What are you trying to fit in it? Mine fits a Nikon D80 with a 80-200 2.8 lying on the side (Sorry haven't tried the Canon equivalent yet). No problem fitting quite big zooms in it. But check the hight. My 80-200 is about the tallest lens a can fit standing up.
Jul 08, 2010 00:42 | #3 renzir, тhank you!
AdamC Goldmember 3,719 posts Joined Jul 2007 Location: newcastle.nsw.au More info | It's definitely not wide enough for 3 lenses - the only way you'd get them to fit is if two of them are short enough to go in stacked (with a piece of foam in between.)
Jul 08, 2010 06:24 | #5 AdamC wrote in post #10497109 It's definitely not wide enough for 3 lenses - the only way you'd get them to fit is if two of them are short enough to go in stacked (with a piece of foam in between.)... It's bad. Would be desirable more place. I then probably will take F-3x.
renzir Hatchling 6 posts Joined Jul 2009 More info | Jul 08, 2010 08:06 | #7 phgraf wrote in post #10497048 renzir, тhank you! I should place: - D90 + nikkor 70-300VR - nikkor 16-85 - nikkor 50/1.8. Сhoose Domke F-803 or F-3x. If you are able to fit the camara with the 70-300 standing, you may be able to Get these three lenses in a three compartment insert (fa230) or stack them as mentioned. But i think a f-3x may be better since its also nice to have room for some extra bits and pieces. But why have only one bag, you sooner or later end up with both any way ( bagholism)
good advice
hfgarris Goldmember 1,760 posts Likes: 11 Joined Feb 2009 Location: Cedar Rapids, Iowa More info | Jul 08, 2010 11:20 | #9 You might check out the Domke J-803 ... similar but just a bit bigger (4.5" thick).
Jul 08, 2010 14:50 | #10 |
hfgarris Goldmember 1,760 posts Likes: 11 Joined Feb 2009 Location: Cedar Rapids, Iowa More info | Jul 08, 2010 16:22 | #11 The interior dimension of the J-803 is specified at 4.5" thick, which is the same as a Canon 5D sized camera (4.5" from base plate to top of pentaprism). The F-803 is only specified as 4.0" thick, so that bag will bulge out a bit with that size camera.
Jul 09, 2010 10:34 | #12 тhank you!
Jul 21, 2010 10:44 | #13 Has received today J-803. Great bag! The camera, all lenses and even SB-900 is located.
hfgarris Goldmember 1,760 posts Likes: 11 Joined Feb 2009 Location: Cedar Rapids, Iowa More info | Jul 21, 2010 11:06 | #14 I'm glad it is working out for you. Domke makes great bags, enjoy the J-803!
| Latest registered member was a spammer, and banned as such! 2856 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
