kuwazome wrote in post #10499371
Why you need so many lenses for a studio setup? You do know you'll be shooting everything at f/8
so it doesn't really matter what lens you use, just as long as the focal length is right. All you probably
need for a lens is 24-105, unless you really want a 24-70 for one stop, which is useless in studio.
Maybe a f/1.4 might be useful for special usages, but you need lights that go really dim.
If you really want to save $ you can use primes... probably a 50 and 85, since "foot zooming" is perfectly
fine when there's nothing in the background except solid color.
You would need at least 4 light stands, two for your cheap monos, two for your backdrop.
Spend $30-60 on 9-12 feet seamless paper, muslin looks really cheesy imho, you wouldn't see it
in a mag. The color you want is white, its much easier to do high key than neutral gray. Low key and
black background can be done via softbox and distance between model and paper.
For lights go with Alienbee or Genesis, should be more than enough. Grids would be nice.
You should forget umbrellas, they just spill way too much light for indoor use, probably only useful
on location. Spend a bit more and get some cheap Photoflex softboxes, one 24x36" , one 45"x60".
Keep in mind the big softbox is
massive but you'll need it for full length since umbrellas
will have fall off and the small softbox wont be big enough.
Go with cactus v4s, since its indoors you have no need for really good triggers.
Most importantly you need a
ton of space, enough width to fit the paper, and about 30-35 feet in
length so that you can adjust the model to paper distance between 5-15 feet and leave 5-15 feet for
you to play with the light distance, on top of that enough space for you to use a 50-85 for full length.
On a crop body, about 15-17 feet is enough to get full body on a 200mm, so use that as a reference.
Don't bother with shooting models with wide, distortion plus getting other stuff like the floor and
ceiling is just not good. The only time you would even do this is for distorting the legs to make them
skinnier, but frankly if the models are skinny it shouldn't be needed.
The Zarias article is really good as recommended above, but that flooring might be hard to find.
