Thread started 07 Jul 2010 (Wednesday) 23:45
Help! Looking for a Good Tripod
djrtbrahma
Joined Jun 2010
Jul 07, 2010 23:45 |  #1
I am looking for a good tripod to use with my Canon XS. I need a tripod that is tall enough for me since I am 6'3. I also want a tripod that can get very low to the ground for macro or close-up shots. I am on a budget of $100. Thanks in advance.
Canon Rebel XS EF-S 18-55mm f/3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS
Hardcore
Jul 08, 2010 09:05 |  #2
Check out Vanguard tripods. They are very reasonably priced and the quality is very good. It has a multi-angle adjustment so you can position the tripod in many different positions. Little bit more than your budget, but it should work great.
I used my Vanguard Carbon fiber 254ct for macro all the time and love it!
You should be looking at the Vanguard 263at which is the aluminum version and can be had for around $140 dollars. The extra $40 is worth the cost and you'll be happy you spent it.
GEAR
Website (external link)
tvphotog
Jul 08, 2010 11:32 |  #3
Check the Manfrotto line of aluminum sticks at B&H. They're heavy, but match your criteria.
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
commking
Jul 09, 2010 00:27 |  #4
I am 6' 1'', and bought a Manfrotto model 055CX3.
Contrary to the previous post, mine is quite light - I got a carbon fibre model. Much lighter than the steel models. They are available in various heights, and a bigger one to suit my height was not a problem - it will be fine for your height also. The weight on this model is fantastic - so light.
Check it out here:
http://www.amazon.com …um-Castings/dp/B001GIPR5I (external link)
I would also recommend this to go with it:
http://www.amazon.com …B000184N22/ref=​pd_sim_p_1 (external link)
Just pull the trigger, and adjust the camera anyway you want - has an inbuilt spirit level.
john-in-japan
Jul 09, 2010 00:41 |  #5
Forgive my negativity, but good+tripod+$100 don't seem to compute. I have said before here that a tripod is a forever purchase. I recommend going to a shop and trying them out. Light + tall = Often equals unstable. If you are staying with that camera forever and will never get a heavy zoom or prime, it could be the right combination.
Cheers,
John
JohnW
5D Mark II Dual Battery Grip, [COLOR=black], 200 f/2.8L, 70-200 f/2.8L II IS, 24-70 f/2.8L 180Macro f/3.5L[COLOR=black], 85 II f/1.2L[COLOR=black], 17-40 f/4L, 50 f/1.4, 50 f/2.5 Compact Macro, MPE-65, 550EX, 400L f.2.8L IS, 580EXII, Canon RingFlash, RRS Perfect Portrait Pkg., Velbon with PH275 and Slider, bunch of filters, Canon 1.4X & Having Fun! http://kamogawa.smugmu​g.com/external link
Buckieh
Jul 09, 2010 00:50 |  #6
commking wrote in post #10503729 (external link)
Check it out here:
Apparently you did not read his post! 100 dollars... not 500 like those two links.
Check out dolica dude, this is the one I got, its very good for the price. http://www.dolica.com/​product.php?id=107 (external link)
Gear: 450d, 18-55mm, 17-85mm, Canon 50mm f/1.4 Tiffen 67mm CP, Dolica AX620B100 Tripod, CS4, DA camera bag
http://www.flickr.com/​photos/buckieh/ (external link)
argyle
Jul 09, 2010 07:14 |  #7
Buckieh wrote in post #10503800 (external link)
Apparently you didn't read his post either ;) The Dolica has an 18" minimum height...the OP needs something much closer.
OP: You may need to up your budget...I seriously doubt that you'll find something "good" for only $100...that's a bit unrealistic IMO. Then again, it depends on how you define "good". But with your stated budget, you may need to scour the used forum or your local Craigslist. Nothing wrong with that, either...
Buckieh
Jul 09, 2010 18:46 |  #8
argyle wrote in post #10504619 (external link)
I did, and thats the best hes going to get for his budget and height. He is going to have to make a compromise.
SkipD
Joined Dec 2002
Jul 09, 2010 19:03 |  #9
djrtbrahma wrote in post #10496851 (external link)
You're going to find that you need to up the budget to around $300 to get what you really want in a package that will last you a while.
The most popular (for very good reasons) choice for your needs would be the Manfrotto 055XProB tripod topped with the Manfrotto 498RC2 ball head.
Skip Douglas
djrtbrahma
Joined Jun 2010
Jul 09, 2010 20:53 as a reply to  @ SkipD's post |  #10
Thanks for all the feedback. I like the Dolica for the price. I am looking for something cheap as a starter tripod and the Dolica is perfect right now. I don't plan on using it forever, just right now. I plan on buying something a lot better in a few months.
Does anyone know anything about the brand Sunpak tripods?
SkipD
Joined Dec 2002
Jul 09, 2010 21:21 |  #11
You could use a bean bag today as long as you have something solid to put it on. That would be much more stable than a cheap tripod.
You'd be amazed at how much money some folks have poured down a drain buying one cheap tripod after another before finally getting something that works well and remains intact for a significant time.
Skip Douglas
djrtbrahma
Joined Jun 2010
Jul 09, 2010 21:34 |  #12
SkipD wrote in post #10508710 (external link)
How many bean bags should I use? Do you know a good place to buy bean bags? Or would a ziplock bag full of beans work?
JohnJ80
Jul 09, 2010 22:57 |  #13
djrtbrahma wrote in post #10508622 (external link)
Unfortunately, I can't believe that the Dolica is any good either. Also, the cheap Sunpaks are also no good. Most of this sort of stuff is set up for home video camera use. The heads will droop and slip, the support is minimal, the ability to dampen vibration is almost non-exsistent. In point of fact, I have a cheapie (I believe it's a Sunpak) that in a light breeze (10mph or so) actually will hit mechanical resonance and is worse than handholding. I did some testing of a Velbon against some gitzo's I own, and the Velbon was an order of magnitude or more worse - it was so bad you wouldn't even want to use it.
Skip is right. If you want something that is going to be stable for a starter tripod, you are going to spend about $300 - and it won't be very light.
Read these:
http://bythom.com/supp​ort.htm (external link)
http://www.luminous-landscape.com/essays/t​ripods_&_heads.shtml (external link)
http://markins.com/cha​rlie/report4e6.pdf (external link)
You are advocating going down the (wrong) path that Thom Hogan describes. He's right and I'm living proof (that's why I have the Sunpak and the Velbon junk). All tripods are a hassle. the better ones are much, much less of a hassle and they work. The cheap ones are a huge hassle and will drive you nuts - and they don't work.
Of course, somebody will post a very sharp picture that was taken on a cheap crummy tripod (in the absence of vibration, of course) and claim to refute all this. Yes, it is possible to get a good image off of a bad tripod, it's just going to not happen all that often, and those times must be in the absence of vibration.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
CxThree
Jul 09, 2010 23:00 |  #14
Please please please take this advice.
Save up for a good tripod. Manfrotto makes some good options under $200 and they are MILES above the cheaper options like dolica. I own a dolica and its crap compared to my manfrotto. I bought it from amazon when I read so many good reviews about it. HYPE. No way I would put my capera on that thing.
Save your money and get a good, stable tripod. You will not regret it at all.
Canon EOS 5D MKIII, 7D
Canon Lenses : 70-200 F2.8L II IS : 24-105 F4L IS : 16-35 F2.8L : 50mm F1.4 : 85mm F1.8 : 100mm F2.8 Macro : 10-22mm
4x 600EX-RT
Speedotron Black Line
boomer ­ mitra
Jul 10, 2010 04:17 |  #15
Vanguard tripods are the best you can get under your budget
4,820 views & 0 likes for this thread, 20 members have posted to it.
2798 guests, 161 members online
