Hi all,
I just got myself a HP LP2475W, as it is considered to be a good monitor for image work, having a s-ips panel and all that, at a very reasonable price.
However, I do find that there seems to be a slight colour gradient or colour shift, from left to right, from light pastel blue to light pastel pink. Is this normal?
I've tried everything, recalibrating well over 10 times, using RGB controsl to set th ewhite point, and the standard optiosn to set the white point, but i can't get rid of it. Furthermore, I turned lights off and on, pivoted the monitor degrees (portrait mode; it is a monitor which allows pivoting), turned it in different directions, no matter what I do, it stays the same, this colour gradient stays in the same physical spot, so it seems hardware related.
I am just wondering whether this is normal or not, or whether I got a faulty specimen.
Thank you in advance for any replies.
BTW, my old monitor has a slight gradient, too, but that is a slight brightness gradient, no colour shifting of any kind.
Kind regards, Wim
