Would I be better off with an M10 or a Q3? My lenses are in my sig and I don't have any collars for any of them.
jb1911 Senior Member 492 posts Joined May 2010 Location: Chicago area More info | Jul 09, 2010 11:45 | #1 Would I be better off with an M10 or a Q3? My lenses are in my sig and I don't have any collars for any of them. 7D/BG-E7 - 580EXII - EF-S 17-55mm f/2.8 IS USM - EF-S 60mm f/2.8 Macro USM - EF-S 10-22mm f/3.5-4.5 USM - in a Domke F-2RW
tvphotog Cream of the Crop More info | Jul 09, 2010 12:49 | #2 For me it would depend on the sticks. For a travel tripod such as the Gitzo 1541t, get the Q3t. For the 2 series or equivalent, the M10. The 2 series and M10 will give you more stability, the travel setup more portability. Either will handle your kit. Jay
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Jul 09, 2010 17:06 | #3 What tripod legs or monopod are you intended to mount it on? [Gear List | Flickr
Jul 09, 2010 18:38 | #4 I've got a Manfrotto 3221W and I don't hike with it. I have a monopod that I carry around, but the tripod stays home. 7D/BG-E7 - 580EXII - EF-S 17-55mm f/2.8 IS USM - EF-S 60mm f/2.8 Macro USM - EF-S 10-22mm f/3.5-4.5 USM - in a Domke F-2RW
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jul 09, 2010 22:41 | #5 The Markins ballheads should be paired by tripod size. Any of them are able to hold all but the biggest lenses. They were designed to match up to the Gitzo line of tripods. Here's how that works out. Obsessive Gear List
boomermitra Mostly Lurking 10 posts Joined Jul 2010 More info | Jul 10, 2010 04:21 | #6 Q3 series 1 can be useful for you.
Jul 10, 2010 09:11 | #7 Thanks for the info. From what you say, I measured the round plate on the top of my legs and it matches up exactly in size with the Q3 (2.20 inches). I didn't think about matching it to the legs and not the lenses and camera I'm using. I love this place. 7D/BG-E7 - 580EXII - EF-S 17-55mm f/2.8 IS USM - EF-S 60mm f/2.8 Macro USM - EF-S 10-22mm f/3.5-4.5 USM - in a Domke F-2RW
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Jul 10, 2010 13:33 | #8 I'd suggest the M10 for the 70-200. You say you don't have a lens collar and I would encourage you to get one because it makes the whole assembly balance better, which is the real issue rather than pure weight. Richard
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jul 10, 2010 15:03 | #9 I use my 70-200 just fine on my Q3. In fact, I use my 300 f/4 on the Q3 as well with zero problems. You fit these heads to the tripods. Any of the markins head can pretty much hold any lens/camera combination. Obsessive Gear List
Jul 10, 2010 17:48 | #10 I just ordered a Q3 and a P50D plate. Now I have to find a tripod collar that doesn't cost $150. Any suggestions? 7D/BG-E7 - 580EXII - EF-S 17-55mm f/2.8 IS USM - EF-S 60mm f/2.8 Macro USM - EF-S 10-22mm f/3.5-4.5 USM - in a Domke F-2RW
keitaro Senior Member 605 posts Joined Dec 2005 Location: Vancouver, BC More info | Jul 10, 2010 19:09 | #11 ^ what do you mean by a tripod collar?
Jul 10, 2010 19:43 | #12
JohnJ80 Cream of the Crop 5,442 posts Likes: 2 Joined Oct 2006 More info | Jul 11, 2010 09:25 | #14 There are knockoff collars for <$35. Obsessive Gear List
Jul 11, 2010 11:05 | #15 I know, I've seen some as low as $15, but they are plastic. Is anyone happy with their knockoff? If so, wheredya get it? 7D/BG-E7 - 580EXII - EF-S 17-55mm f/2.8 IS USM - EF-S 60mm f/2.8 Macro USM - EF-S 10-22mm f/3.5-4.5 USM - in a Domke F-2RW
| Latest registered member was a spammer, and banned as such! 2802 guests, 161 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
