Also - consider that most users could get completely different results using the same image and the same apps. This kind of comparison is sort of arbitrary without some common intent or relationship among the settings of thee various applications to somehow normalize the results. Also, if a user does not know how to use a particular application, the results may not be so great. For example, the HDR PhotoStudio image is lifeless and blue, but the application has several ways to remedy this, including a 32 bit WB tool - and, CannedHeat, I know you are no fan of HDR PhotoStudio for the installation problems you had, but in your statement
They market themselves as the answer to realistic HDR, but in this image I think they did a poor job - one of the worst.
it is somewhat important to note that "they" (the creators of HDR PhotoStudio) didn't do anything with this image. This tonemap is a function of the OP's use of the app. Nothing against the poster, it is just something that is pretty obvious - like most of the other apps out there, HDR PhotoStudio has controls for local and global contrast, exposure, in addition to spot color correction and 32 White Balance and sharpening. The CS5 image is a mess as well, with a color cast and muddy contrast - this, again, is something that can be addressed with the multitude of tonemap settings in the new HDRPro part of CS5.
I would guess that the OP is most familiar with using Photomatix.
If all of the apps had an "Auto" function and that was all that was done to generate the images, then I could see that at least be a somewhat reasonable comparison to start with.
Kirk
