tuttifrutti wrote in post #10512320
To be honest guys, i'd not really looked too hard at DPP and wasn't aware of the ability to save a recipe to the clipboard so i'll give it a go.
That said, I would still have to select each individual image to complete the task (albeit, quicker with the saved recipe)
No, it's much easier than that. I just did this yesterday on a group of shots - same subject, same lighting, so I wanted the same processing.
- open one image, apply adjustments as needed, save recipe to clipboard;
- select "invert selection"
- paste recipe to image, which will apply to all the selected images - that is, everything but the first.
Another approach if there are several scenes with different lighting is to group them by lighting/processing and tag them "1", "2" or "3". Then for editing you can select all images with a given tag.
EDIT: if you're doing multiple groups, as above, rather than "save to clipboard" you'd usually want "save recipe in file" and "read and paste recipe from file". Your edit files can be named to match the 1, 2 or 3 tags.
-js
