Thread started 10 Jul 2010 (Saturday) 17:47
Carrying backpack for hobbyist?
J.Litton
Jul 10, 2010 17:47 |  #1
I am getting into photography, and need a nice carrying backpack type case.
I currently have a T2i, and the 100-400 L is my largest lens. I will also be carrying a 55-250, and kit lens.
Any recommendations? Will the Canon backpack fit it all ? Its hard to tell online what will hold the T2i and 100-400 connected to it..
Thanks!
7D MK II.17-40L.100-400L.500L
www.jlitton.com (external link)
www.facebook.com/jlitt​on.nature.photography (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Jul 10, 2010 17:54 |  #2
If you are only carrying the camera and the lenses you mentioned it would. But the zippers on the canon backpack have a tendency to pull open under a full load so I would be wary of it. I used small carabiners to lock the zippers together. But if can spend a bit more the lowepro mini trekker is a better bag of similar capacity and better quality
J.Litton
Jul 10, 2010 18:46 |  #3
Wow it may be nicer, but 4x the price!
harcosparky
Jul 10, 2010 18:54 |  #4
NothingRemains10 wrote in post #10513000 (external link)
Keep in mind the value of what you are carrying.
What'd that 100-400L set you back? I know new they are priced somewhere around $1600.00. Add in the other stuff, and you get the idea.
I realize that money spent on a backpack is tough, because it not an active part of the picture taking process but it protects what is! ;)
FWIW - I am in the same boat as you, looking at some new bags/packs.
I saw the Canon one at Best Buy and my initial thought was it wouldn't do the job.
Also you might want to consider carrying the camera body and lend separated.
I believe that a lens and body NOT ATTACHED might be able to better handle being jarred a bit.
I'm speaking from experience, as I had a 70-200 f/4 L attached to a 7D inside a camera backpack and it fell from about 3' in height. The camera escaped unharmed, but the lens needed to be repaired.
nitehawk55
Joined Jun 2010
Jul 11, 2010 08:58 as a reply to  @ harcosparky's post |  #5
I just got a Lowepro Flipside 400 which will work well for me . There is a 200 and 300 model as well . Here is a youtube demo of the 400.....
http://www.youtube.com​/watch?v=DXCAMU2A2ws (external link)
SuzyView
Jul 11, 2010 09:00 |  #6
Yes, the Flipside would work, but if I had just 2 large lenses and one camera body, I'd get a nice lens case and a smaller backpack. How often do you need both?
J.Litton
Jul 11, 2010 09:57 |  #7
I think I am going to go with the Flipside 200. Just not sure if it is much of a hassle to get items out of it. That is about the price I am wanting to spend though. I should have planned all this out better and not been in such a rush :(
lannes
Jul 11, 2010 11:14 |  #8
Tamrac Evolution series is another alternative
nitehawk55
Joined Jun 2010
Jul 11, 2010 12:18 |  #9
NothingRemains10 wrote in post #10515608 (external link)
You might be best to plan for the future and get a bit bigger than you need . While the 200 may work for you now the 300 is only marginally larger and a bit more cost wise so that might be something to consider .
It doesn't take long to get it off and flip it around but my thought is if you are in a target area you should have your camera and choice of lens out and around your neck ready to shoot . I like the fact that no one can access your gear from behind or beside you .
V-Wiz
Joined Sep 2009
Jul 12, 2010 01:35 |  #10
Seems like the Canon fits more than the flipside 300. Right?
Gripped 5D Mark II l 24-105 F/4 L l 70-200 F/4 L l Tokina 12-24 F4 l 50mm 1.8 l Sigma 600 Mirror l B+W KSM CPL l B+W 6stop ND filter l Hitech 0.6 GND l YN-468 Flash l Kenko Pro 300 1.4 TC l Induro Tripod, Vanguard 250 Ballhead.
Buckieh
Jul 12, 2010 01:40 |  #11
Get the deviantart camera bag, its what I use, kicks ass.
Gear: 450d, 18-55mm, 17-85mm, Canon 50mm f/1.4 Tiffen 67mm CP, Dolica AX620B100 Tripod, CS4, DA camera bag
http://www.flickr.com/​photos/buckieh/ (external link)
V-Wiz
Joined Sep 2009
Jul 12, 2010 11:29 |  #12
Buckieh wrote in post #10519533 (external link)
Not bad at all.
1,591 views & 0 likes for this thread, 8 members have posted to it.
2871 guests, 169 members online
