I am trying to learn everything I can about my camera
reneefk Member 217 posts Joined Jul 2010 Location: Los Angeles, CA More info | Jul 10, 2010 22:45 | #1 I am trying to learn everything I can about my camera
LordV Macro Photo-Lord of the Year 2006 More info | Jul 11, 2010 00:51 | #2 Pics are not too bad. Suspect you may need to use manual focus on the camera when doing closeups/macro with it. http://www.flickr.com/photos/lordv/
Jul 11, 2010 01:21 | #3 thank you, I really appreciate the input!
Snydremark my very own Lightrules moment More info | Not too bad for getting used to shooting macro. Be sure to make sure that your AF point is set to center, and adjust the AF point size to its smallest size. AF points are not precise indicators of the point of focus; they're more like guidelines for where the camera will grab focus. - Eric S.: My Birds/Wildlife
Jul 11, 2010 01:32 | #5 Thanks! I love all the tips. That was literally my first time ever using macro.
Snydremark my very own Lightrules moment More info | Also, were you actually using the Macro (flower icon) setting? or just shooting in as close as you could get? - Eric S.: My Birds/Wildlife
Yup, I was using the macro setting. I had switched it over and tried in auto for a few pics because I was getting frustrated that they were blurry.
O.K. I took the suggestions and tried again today. Are these any better? (I included a really close cropped version of each pic)
Snydremark my very own Lightrules moment More info | Definitely looks like that helped. Can you simply get in closer on some subjects before taking the shot? If you have set the Macro mode on, you *should* be able to get right down within a couple inches and still get focus with one of those (or, I could on my G series Canons anyway). - Eric S.: My Birds/Wildlife
Jul 11, 2010 19:30 | #10 thank you so much. I really do appreciate the comments! I will keep practicing.
Snydremark my very own Lightrules moment More info | Jul 11, 2010 21:24 | #11 reneefk wrote in post #10517942 thank you so much. I really do appreciate the comments! I will keep practicing. Maybe I need to try on some things that aren't moving. I did try to get within a couple inches and every time I would get that yellow square/exclamation mark symbol (which according to the manual means the camera can't focus) so I backed off until it went away. Which doesn't make sense to me because the book says on macro it will do: 1.2 in.-1.6ft from the end of the lens and I know I wasn't that close. You'll also need to make sure that there is some contrast on your subject within the AF frame for the camera to focus on. For example, if you are trying to focus on a solid color object you may not be able to get focus. - Eric S.: My Birds/Wildlife
ah, ok..that makes sense.
| Latest registered member is MWCarlsson 1634 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
