This might be a dumb question, but what is old style jpeg compression? And is it ok, or a bad thing? I notice when looking at the EXIF data on photos I've uploaded to Flickr, that the compression says JPEG (old style.)
Kasrielle Goldmember More info | Jul 10, 2010 23:49 | #1 This might be a dumb question, but what is old style jpeg compression? And is it ok, or a bad thing? I notice when looking at the EXIF data on photos I've uploaded to Flickr, that the compression says JPEG (old style.)
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jul 11, 2010 03:36 | #2 I've never heard of it. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
BobbyDigital Member 176 posts Likes: 1 Joined Mar 2010 Location: Melbourne More info |
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 11, 2010 05:15 | #4 I suppose that's just 'regular' jpg compression, as opposed to jpg2000: http://en.wikipedia.org/wiki/JPEG_2000 "I think the idea of art kills creativity" - Douglas Adams
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Jul 11, 2010 10:36 | #5 JPEG has evolved many times over the years since it's birth. It now includes standard, optimised and progressive methods as well as the aborted JPEG 2000 format which is destined to die and will soon be evolved again to be the Microsoft HD Photo spec which was ratified by J.P.E.G. to be the next step. My collection of boxes with holes
Jul 11, 2010 12:53 | #6 HankScorpio wrote in post #10515736 JPEG has evolved many times over the years since it's birth. It now includes standard, optimised and progressive methods as well as the aborted JPEG 2000 format which is destined to die and will soon be evolved again to be the Microsoft HD Photo spec which was ratified by J.P.E.G. to be the next step. The oldest method currently in use is "Standard" but there are older which were phased out and can now only be read and not written by modern software. Typically (old style) in EXIF means anything but the most current method and I know Flickr supports the latest MS HD Photo spec which is now known as JPEG XR. Thanks for the explanation! When I save my pics in PSE5, I just use the extention .jpg, which I suppose is the old or standard style. JPG 2000 is also an option but I've never used it. And I'm guessing PSE 5 is too old to have the newest options. So is it ok to continue to do what I've been doing?
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Jul 11, 2010 13:03 | #7 Almost nothing supports jxr format at the moment. Even CS5 doesn't by default. It will eventally make it's way into cameras as it supports up to 48bit and lossless compression but for now, ignore it. My collection of boxes with holes
tonylong ...winded More info | Jul 11, 2010 16:50 | #8 Kasrielle wrote in post #10516342 Thanks for the explanation! When I save my pics in PSE5, I just use the extention .jpg, which I suppose is the old or standard style. JPG 2000 is also an option but I've never used it. And I'm guessing PSE 5 is too old to have the newest options. So is it ok to continue to do what I've been doing? There should be no problem using the tools you have -- otherwise any jpegs created some time "back then" would break. Jpeg is designed to be universally compatible, even if it uses "old" compression. Tony
Jul 11, 2010 17:07 | #9 tonylong wrote in post #10517208 There should be no problem using the tools you have -- otherwise any jpegs created some time "back then" would break. Jpeg is designed to be universally compatible, even if it uses "old" compression. Of course there can be benefits from upgrading your Elements version, and there may be benefits for using newer compression algorithms, but this is not a "required" upgrade. I have PSE 8 but haven't installed it because there seem to be so many problems with it. When I get my next computer and Windows 7 (I'm still running XP) I'll have to upgrade, but I think I'll wait until then...
tonylong ...winded More info | Jul 11, 2010 17:20 | #10 Kasrielle wrote in post #10517286 I have PSE 8 but haven't installed it because there seem to be so many problems with it. When I get my next computer and Windows 7 (I'm still running XP) I'll have to upgrade, but I think I'll wait until then... I'm not aware of problems with Elements 8 on XP other than your normal glitches that occasionally can happen with any software. The question is whether PSE8 will provide benefits to you. You could install it, test it out, and if you encounter problems revert to PSE5...? Tony
Jul 11, 2010 17:30 | #11 tonylong wrote in post #10517355 I'm not aware of problems with Elements 8 on XP other than your normal glitches that occasionally can happen with any software. The question is whether PSE8 will provide benefits to you. You could install it, test it out, and if you encounter problems revert to PSE5...? A lot of folks have problems with the organizer, which worried me. And I don't think there are any huge editing advances, are there? Most folks on the adobe support forums seem to think 5 is one of the best versions...
tonylong ...winded More info | Jul 12, 2010 01:38 | #13 Kasrielle wrote in post #10517404 A lot of folks have problems with the organizer, which worried me. And I don't think there are any huge editing advances, are there? Most folks on the adobe support forums seem to think 5 is one of the best versions... Well, the Adobe forums would definitely be a good place for info there! If the weight of advice is to stick with PSE5, then go for it! You can do a ton of stuff with Elements, and there are add-ons that let you do more. So, go for it! Tony
HankScorpio Goldmember 2,700 posts Likes: 1 Joined Aug 2007 Location: England, baby! More info | Jul 12, 2010 11:30 | #14 BobbyDigital wrote in post #10519039 So is the old compression any different in quality to the newer JPG2000? Cheers JPEG 2000 is very different to standard JPEG in the way it encodes. Compression artefacts show as rings instead of the blocks you see with standard jpeg but 2000 also supports lossless compression as well as security features and also houses motion jpeg video format. It's kind of an abandoned format though as it didn't offer much over normal jpeg and couldn't offer enough over things like tiff for higher end use. It is a nice format though, better in many ways to JPEG XR. My collection of boxes with holes
| Latest registered member is semonsters 1468 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
