Hi
I use my EOS 7d camera for mainly aircraft/air show photography.
When using my 100-400mm f5.6 L IS I can never seem to get a razor sharp image as often I see with other photographers who were at the same show in roughly the same position.
I nearly always use the 400mm setting.
I attach a lens test shot I took this afternoon, are these the results you would expect from such a lens? Or is it just my incompetence?
Does anyone have any advice on using the Image Stabiliser for such situations as fast moving aircraft at distance?
Thanks for looking.
Philip L Jackson
