Hello all,
I am about to purchase a used GT3540XLS. Any reason why I should spend the extra on its successor, the GT3541XLS??
Thanks for your input.
seabee_shooter Member 228 posts Likes: 1 Joined Oct 2008 More info | Jul 11, 2010 23:45 | #1 |
Jonta Senior Member 540 posts Joined Jan 2008 Location: Trondheim, Norway More info | Jul 12, 2010 00:07 | #2 You should replace "predecessor" with "successor". Very confusing (:
Jul 12, 2010 00:20 | #3 Woops... edited... thanks. I can't find any difference in the specs I've found. Both seem to weigh approx 4.4 lbs, min height of 4", max of 78" (which is why I need this model), load capacity of 39 lbs, carbon fiber, and 4 leg sections. Anything I'm missing? It is hard to find reliable information on the older 3540. Flickr
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | As far as I'm aware, the only additions on the 3541 are the facility to put a weight hook under the support plate and a new friction pad on the top surface. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Jul 12, 2010 22:37 | #5 Canon Bob wrote in post #10521374 As far as I'm aware, the only additions on the 3541 are the facility to put a weight hook under the support plate and a new friction pad on the top surface. FWIW, I use a 3540XLS with my 600/4 and occasionally the 300/2.8 and am more than happy with it. Bob
Flickr
ELT_Photo Senior Member 301 posts Joined Jan 2008 Location: Royal Oak, MI More info | Jul 13, 2010 00:37 | #6 I've been using my 3540XLS and wimberly wh200 for 3+ years with my 500 f/4 and its a great tripod for super telephoto lenses. My friend has the same set-up for his 600 f/4 and 300-800 Sigma. I can't see how the 3541XLS can have a lower min. height as the 3540 legs Passion - Dedication - Inspiration (and some gear)
Jul 13, 2010 01:11 | #7 ELT_Photo wrote in post #10525803 I've been using my 3540XLS and wimberly wh200 for 3+ years with my 500 f/4 and its a great tripod for super telephoto lenses. My friend has the same set-up for his 600 f/4 and 300-800 Sigma. I can't see how the 3541XLS can have a lower min. height as the 3540 legs can rotate to 90 degs. Nice! Must be an inaccurate rumor then...can't wait to get it in the mail. I've been using the WRONG tripod for too many years. Flickr
| Latest registered member is icebergchick 1343 guests, 154 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
