Generally speaking do step up rings work pretty well for sharing filters like a circular polarizer? I've got a 72mm filter and currently have two other lenses with filter sizes less than that. Can I use a step-up ring pretty effectively?
imahawki Goldmember 1,455 posts Likes: 1 Joined Aug 2008 Location: Omaha, NE More info | Jul 12, 2010 13:35 | #1 Generally speaking do step up rings work pretty well for sharing filters like a circular polarizer? I've got a 72mm filter and currently have two other lenses with filter sizes less than that. Can I use a step-up ring pretty effectively? Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
xcel730 Senior Member 603 posts Joined Dec 2009 Location: New York More info | Jul 12, 2010 14:00 | #2 Yes, step-up rings work perfectly fine. I have 77mm polarizer, and ND filters and I share them with all my lenses. ________
edrader "I am not the final word" More info | Jul 12, 2010 14:34 | #3 [QUOTE=imahawki;10522143]Generally speaking do step up rings work pretty well for sharing filters like a circular polarizer? I've got a 72mm filter and currently have two other lenses with filter sizes less than that. Can I use a step-up ring pretty effectively?[/quote] http://instagram.com/edraderphotography/
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | They'll work, but sometimes they'll prevent you from using the lens hood without a bit of a hassle. Some of the rings are also pretty crappy. IF you're going to go that route, I'd go with a B+W ring...the filter threads on and off like butter, ditto for attaching the ring to the lens. The cheapies seem to have coarse threading, which makes binding that much more of a possibility. My advice would be to spend the extra $10 or so for a B+W ring... "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
Jul 12, 2010 19:51 | #5 Thanks guys. It think so far every lens I own is a different filter size. Olympus OMD E-M10 | Olympus 25 f/1.8 | Olympus 45 f/1.8 | Olympus 75 f/1.8 | Olympus 9-18 f/4-5.6 | Olympus 14-42 f/3.5-5.6 | Olympus 40-150 f/4-5.6
| Latest registered member is RawBytes 1399 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
