Thread started 15 Jul 2010 (Thursday) 13:18
Hard Drive Performance Question
mattyb240
Jul 15, 2010 13:18 |  #1
I was having a conversation at work, and basically I wanted it settled.
We were discussing hard drives as my friend is replacing his laptop drive, this got onto capacities and performances.
As capacity increases does performance suffer? They believe a 160gb drive (example) would be faster than a 1tb drive. Assuming both were the same manufacturer, rpm, and interface is this true?
Can anyone elaborate please? Everything I have googled including looking at hard drive specs seem to support my side as far as read/write times and latency etc?
Sorry for the random posting!
Matt:D
Deviant Art (external link)
In2Photos
Jul 15, 2010 14:10 |  #2
Usually the larger drives perform better as the data is closer together and the spindle does not have to travel as far. Better yet just pick up an SSD and wipe the floor with the HDD. ;)
Current Gear and Feedback
mattyb240
Jul 15, 2010 14:27 |  #3
In2Photos wrote in post #10542654 (external link)
I know it was a general discussion, but unfortunately I don't know the technical innards, but there argument seemed flawed.
MaxxuM
Jul 15, 2010 14:58 |  #4
Nope, he's right. The more dense the HDD the less heads have to move to get data. If you had a 120GB HDD at 7200RPM it will be slower (data transfer) than a 1TB HDD at 5400RPM. Add to this that the larger the drive the more advanced they will be since larger HDDs use newer tech than 120GB drives.
mattyb240
Jul 15, 2010 15:02 |  #5
MaxxuM wrote in post #10542986 (external link)
So I am right? The capacity does not get "slower" as it increases? This was basically the argument, including SD cards as well…..
MaxxuM
Jul 15, 2010 15:21 |  #6
mattyb240 wrote in post #10543017 (external link)
Capacity is a measure of how much something can hold and slower describes speed. HDD 'speed' is measured in several ways: spindle speed (RPMs), seek (ms), read/write (mb/s) and so on. RPM is usually a constant (i.e. 7200RPM or 5400RPM). This does not measure data movement. That would be read/write speeds. Seek times measure the time it takes the HDD's head to find the data. Seek times are measured as a 'delay'. Drive capacity is measured in bytes. The more data that can be squeezed into a single inch has been increasing every year. The more dense (capacity) a drive has the less a HDD read/write head has to move to reach that data.
So, it is more than just a trend when I say that the larger the capacity of the drive the more likely it will be able to move more data in a shorter amount of time. There are some exceptions (like Velociraptors, 10,000RPM drives, SSD's and so on).
mattyb240
Jul 15, 2010 15:32 |  #7
Thanks Maxxum I value your detailed input, upon more googling I have found more information about the details you list! Hopefully I will be able to go in tomorrows discussion with a few more facts and bench marks!
Tony-S
Jul 15, 2010 16:43 |  #8
Perhaps most important is platter density. WD can put 375 GB on a platter (187.5 GB per side) and this is what's used in their 750 GB 2.5" drive. They use three of these in their 1 TB drive (which is 12.5mm high).
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
tim
Light Bringer
Jul 15, 2010 17:17 |  #9
As platters get more dense, given the same disk velocity, more data passes under the read head per second so the data comes back faster. If the read head has to move, say to get a different file, that can be slow.
With an SSD/SD card there's no read head so there's less latency, but the throughput isn't a lot higher.
There are hybrid drives now, and most used data (usually the OS) is cached in flash memory on the disk. They're meant to be great value, much faster for common stuff like booting or launching programs, and as fast as a normal disk otherwise.
Tony-S
Jul 15, 2010 17:22 |  #10
tim wrote in post #10543751 (external link)
This is also why 3.5" drives usually perform better. The outer edge is further away, thus greater speed (at the same rpm).
canonloader
Gallery: 6 photos
Jul 15, 2010 18:28 |  #11
I have been trying to find more information on these drives. Actually, I have been talking about them for years with my brother, who was into development of solid state processing decades ago. I can find them for sale now, but there seems to be no information on how you would hook one up in your tower, or what you need to use it as a base for the OS. Can you install windows on one?
Mitch- ____...^.^...____
tim
Light Bringer
Jul 15, 2010 18:36 |  #12
canonloader wrote in post #10544164 (external link)
They look like a normal hard drive to the computer, you can install windows or anything you like on them.
canonloader
Gallery: 6 photos
Jul 15, 2010 18:40 |  #13
I read that they have to be DMA capable though to take an OS, and I'm not sure exactly what that means, and have not seen "DMA capable" on any of the advertised statistics for them. For instance, is a CF card DMA capable?
tim
Light Bringer
Jul 15, 2010 18:48 |  #14
You're overthinking this. They work like a normal hard drive.
canonloader
Gallery: 6 photos
Jul 15, 2010 18:55 |  #15
HAHA, I've found that it's much better to over think than over pay. LOL
2,310 views & 0 likes for this thread, 8 members have posted to it.
1462 guests, 144 members online
