hmmm seems to be a text that i DL
#!/usr/bin/env python
# -*- coding: utf-8 -*-
Copyright: Alexander Hadjiivanov 2010
Licence: GPL
Installation: copy the "batchwork.py" file into your $HOME/.gimp-2.x/plug-ins directory.
On Linux and Mac OSX the file must be executable.
The scripts appear under the <Image>/Tools/Batchwork/ menu entry
Version 1.04
In Watermark:
- Added options to select the position and/or number of text lines in the bump map watermark script
Version 1.03
In Watermark:
- The text layer is now created directly in the original image, which is faster and saves memory
- Moved the menu entry to "<Image>/Tools/Batch/Watermark"
- Added a new type of watermarking which can be used in case the visual impact on the image
must be minimal
* The bump map technique yields
Version 1.02
In Watermark:
- Function names and variable names cleaned up and made consistent
- Moved the menu entry to "<Image>/Tools/Batch..." in order to bring all scripts under the same hood
- Added a dropdown option for the file extension
- Added a special case for "JPG"/"JPEG"
- The glob is now case-insensitive
Others:
- Added a script for batch resizing which is aware of the image orientation
Version 1.01
- Added an option for choosing the output directory in the Watermark script
Version 1.0
- Initial release
from gimpfu import *
import os, glob, re
# i18n
import gettext
Batch watermarking with a bump map
Based on the iccii "Texturizer" script (ported from script-fu to python-fu and added a batch mode)
WARNING
Please double-check whether you have selected the correct output directory. If the
input directory and the output directory are the same, the script will replace the
original files.
locale_directory = gimp.locale_directory
gettext.install( "gimp20-batchwork", locale_directory, unicode=True )
BatchWmBump_help = _("Watermarking of multiple images with a bump map.")
BatchWmBump_description = BatchWmBump_help
def python_fu_batchwm_bump(
indirectory,
outdirectory,
ext,
angle,
elevation,
depth,
waterlevel,
ambient,
repetitions,
position,
fontname,
copyright):
if os.path.exists( u''+indirectory ):
if ext == 0:
inglobpattern = u''+indirectory + os.sep + '*.' + "[Jj][Pp][Ee][Gg]"
infilepathnames = glob.glob( inglobpattern )
inglobpattern = u''+indirectory + os.sep + '*.' + "[Jj][Pp][Gg]"
infilepathnames.extend(glob.glob( inglobpattern ))
elif ext==1:
inglobpattern = u''+indirectory + os.sep + '*.' + "[Gg][Ii][Ff]"
elif ext==2:
inglobpattern = u''+indirectory + os.sep + '*.' + "[Pp][Nn][Gg]"
if os.path.exists( u''+outdirectory ):
if infilepathnames:
messagebox = pdb.gimp_message_get_handler( )
pdb.gimp_message_set_handler( 2 ) # send messages in error console
# Start the process
for infilepathname in infilepathnames:
img = pdb.gimp_file_load( infilepathname, infilepathname )
imglayer= img.layers[0]
imgwidth = pdb.gimp_image_width(img)
imgheight = pdb.gimp_image_height(img)
# Process the files
# Perform some initialisation procedures
texture_layer = gimp.Layer(img, _("Texture"), imgwidth,imgheight,RGBA_IMAGE,100,NORMAL_MODE)
pdb.gimp_image_undo_disable(img)
pdb.gimp_image_add_layer(img,texture_layer, 0)
pdb.gimp_drawable_fill(texture_layer, 3)
# Initialise the font with size = 1px in order to avoid meetings with dragons
font_size=1
# Create the texture layer from the string containing the copyright text
textBoxWidth,textBoxHeight,fontAscent,fontDescent = pdb.gimp_text_get_extents_fontname(copyright, font_size, PIXELS, fontname)
if imgwidth>imgheight:
if repetitions==0:
while textBoxWidth < 2*imgwidth/3:
font_size=font_size + 1
if position==0:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/6,imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
elif position==1:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/6,imgheight/2,copyright,0,True,(font_size - 1),PIXELS,fontname)
elif position==2:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/6,5*imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
elif repetitions==1:
while textBoxWidth < 3*imgwidth/5:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/3,5*imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
elif repetitions==2:
while textBoxWidth < imgwidth/3:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/8,imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
texture_layer=pdb.gimp_text_fontname( img,texture_layer,5*imgwidth/8,imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/8,5*imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
texture_layer=pdb.gimp_text_fontname( img,texture_layer,5*imgwidth/8,5*imgheight/6,copyright,0,True,(font_size - 1),PIXELS,fontname)
else:
while textBoxWidth < 4*imgwidth/5:
if repetitions==0:
if position==0:
elif position==1:
elif position==2:
pdb.gimp_drawable_set_visible(imglayer,False)
texture_layer=pdb.gimp_image_merge_visible_layers(img,CLIP_TO_IMAGE)
pdb.gimp_drawable_set_visible(imglayer,True)
pdb.plug_in_bump_map(img,imglayer,texture_layer,angle,elevation,depth, 0, 0, waterlevel, ambient, True, False, 0)
pdb.gimp_image_remove_layer(img,texture_layer)
outfilepathname=re.sub(u''+indirectory,u''+outdirectory,infilepathname)
pdb.gimp_file_save(img,imglayer,outfilepathname,outfilepathname)
pdb.gimp_image_delete(img)
# Give some feedback
pdb.gimp_message("Watermarking completed successfully!")
pdb.gimp_message_set_handler( messagebox )
else:
pdb.gimp_message( _("There are no files in %s") %(indirectory ) )
else:
pdb.gimp_message( _("%s doesn't exist") %(outdirectory) )
else:
pdb.gimp_message( _("%s doesn't exist") %(indirectory) )
Batch watermarking with a difference map
Creates a transparent layer with text, which is merged with the original image layer in
the "Soft light" mode. Depending on the opacity of the text layer, the visual impact on
the image is minimal (with the default settings, the watermark is practically
invisible and does not distract the eye even when applied to low-resolution images,
which can not be said for the bump map technique). The copyright text can be extracted
as follows by using the original non-watermarked image as a "key":
0*. Rescale the original ("key") image to the same resolution as the watermarked one
(skip this step if they are the same size to begin with)
1. Paste the key image as a new layer into the watermarked image
2. Merge down the two layers in the "Difference" mode. What is left is the copyright
text (plus some noise, depending on the file format)
3. The text is most probably still too faint to read, so boost the levels (Colours/Levels...)
until the text becomes readable
WARNING
original files.
BatchWmDiff_help = _("Watermarking of multiple images with a difference map.")
BatchWmDiff_description = BatchWmDiff_help
def python_fu_batchwm_diff(
indirectory,
outdirectory,
ext,
opacity,
fontname,
copyright):
if ext == 0:
elif ext==1:
elif ext==2:
if infilepathnames:
# Start the process
# Process the files
texture_layer = gimp.Layer(img, _("Texture"), imgwidth,imgheight,RGBA_IMAGE,opacity,SOFTLIGHT_MODE)
font_size=1
while textBoxWidth < imgwidth/2:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,imgwidth/2,2*imgheight/3,copyright,0,True,(font_size - 1),PIXELS,fontname)
else:
while textBoxWidth < imgwidth:
texture_layer=pdb.gimp_text_fontname( img,texture_layer,0,2*imgheight/3,copyright,0,True,(font_size - 1),PIXELS,fontname)
texture_layer=pdb.gimp_image_flatten(img)
pdb.gimp_file_save( img,texture_layer,outfilepathname,outfilepathname )
else:
else:
else:
Batch resizing of images. Automatically detects whether the orientation is landscape
or portrait and resizes the image accordingly. The only input is the new value for the
"long side" of the images, which can be either the width of the height. This ensures,
for example, that the resulting images will fit into a square <div></div> element with
a side equal to the new "long side".
BatchResize_help = _("Watermarking of multiple images.")
BatchResize_description = BatchResize_help
def python_fu_batch_resize(
indirectory,
outdirectory,
ext,
new_long_side,
interpolation):
if ext == 0:
elif ext==1:
elif ext==2:
if infilepathnames:
# Start the process
# Process the files
aspect_ratio=float(imgwidth)/float(imgheight)
pdb.gimp_image_scale_full(img,new_long_side,int(round(new_long_side/aspect_ratio)),interpolation)
else:
aspect_ratio=float(imgheight)/float(imgwidth)
pdb.gimp_image_scale_full(img,int(round(new_long_side/aspect_ratio)),new_long_side,interpolation)
pdb.gimp_file_save( img,imglayer,outfilepathname,outfilepathname )
pdb.gimp_message("Resizing completed successfully!")
else:
else:
else:
# Register all plugins
register(
"python-fu-batchwm-bump",
BatchWmBump_description,
BatchWmBump_help,
"Alexander Hadjiivanov",
"GPL License",
"2010",
_("Bump map"),
[(PF_DIRNAME, "indirectory", _("Input Directory"), os.getcwd() ),
(PF_DIRNAME, "outdirectory", _("Output Directory"), os.getcwd() ),
(PF_OPTION, "ext", _("Extension"), 0, ["JPEG", "GIF", "PNG"]),
(PF_SPINNER, "angle", _("Angle"), 135, (0,360,1)),
(PF_SPINNER, "elevation", _("Elevation"), 40.0, (0.5,90,0.5)),
(PF_SPINNER, "depth", _("Depth"), 20, (1,65,1)),
(PF_SPINNER, "waterlevel", _("Waterlevel"), 5, (0,255,1)),
(PF_SPINNER, "ambient", _("Ambient"), 30, (0,255,1)),
(PF_OPTION, "repetitions", _("Number of text lines"), 0, ["1","2","3 or 4 depending on orientation"]),
(PF_OPTION, "position", _("Position"), 1, ["top","middle","bottom"]),
(PF_FONT, "fontname", _("Font"), "Sans"),
(PF_STRING, "copyright", _("Copyright info"), "© your_copyright_info"),],
python_fu_batchwm_bump,
menu="<Image>/Tools/Batchwork/Watermark...",
domain=( "gimp20-batchwork", locale_directory)
register(
"python-fu-batchwm-diff",
BatchWmDiff_description,
BatchWmDiff_help,
"GPL License",
"2010",
_("Difference map"),
(PF_SPINNER, "opacity", _("Opacity"), 5, (0,100,0.1)),
python_fu_batchwm_diff,
register(
"python-fu-batch-resize",
BatchResize_description,
BatchResize_help,
"GPL License",
"2010",
_("Resize"),
(PF_SPINNER, "new_long_side", _("New long side (px):"), 640, (10, 3000, 1)),
(PF_OPTION, "interpolation", _("Interpolation"), 3, ["None", "Linear", "Cubic", "Lanczos"]),],
python_fu_batch_resize,
menu="<Image>/Tools/Batchwork",
main()
