Any tips would be great on shooting high action with little light.
I am using a 1d Mark ii w/ a 70-200mm L F4
every time I have shot at night it dosent work out well so figured I would see advice from the experts!
BaseballPhotography44 Member 58 posts Joined Feb 2010 More info | Jul 16, 2010 16:26 | #1 Any tips would be great on shooting high action with little light.
Jardiniboy Senior Member 508 posts Joined Jan 2008 Location: Waipahu, Hawaii More info | Jul 16, 2010 16:45 | #2 |
BTBeilke Senior Member 827 posts Likes: 1 Joined Aug 2005 Location: Bettendorf, IA USA More info | Jul 16, 2010 17:02 | #3 I'm certainly no expert, but if you can't use flash, the lighting is poor, and you have fast moving subjects, the only thing you can really do is shoot wide open and crank up the ISO. And, of course, you need to keep the shutter speed fast enough to freeze (or at least slow to an acceptable level) the action. Without flash, the best answer is faster glass(but then you are also fighting a shallower DOF). Blane
apersson850 Obviously it's a good thing More info | That (referring to the 70-200 f/2.8 here) doesn't help. One stop larger aperture implies that you can keep going a few more minutes at dusk, but that's it. Anders
Jul 16, 2010 17:20 | #5 BaseballPhotography44 wrote in post #10549891 Any tips would be great on shooting high action with little light. The fastest lens and highest ISO you can get.
Focal Length: 169.0mm Aperture: f/2.8 Exposure Time: 0.0040 s (1/250) ISO equiv: 4000 Exposure Bias: none Metering Mode: Matrix Exposure: program (Auto) White Balance: Manual Flash Fired: No Color Space: sRGB
Focal Length: 200.0mm Aperture: f/2.8 Exposure Time: 0.0050 s (1/200) ISO equiv: 6400 Exposure Bias: none Metering Mode: Matrix Exposure: program (Auto) White Balance: Manual Flash Fired: No Color Space: sRGB
Focal Length: 70.0mm Aperture: f/2.8 Exposure Time: 0.010 s (1/100) ISO equiv: 1600 Exposure Bias: none Metering Mode: Matrix Exposure: program (Auto) White Balance: Auto Flash Fired: No Color Space: sRGB The T2i was set at Program AE exposure and Auto ISO, with the top ISO set at ISO 6400. The equestrian image was helped with Noiseware noise reduction. For whatever reason, half of the arena's lights were not turned on for that horse event.
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Jul 16, 2010 17:47 | #6 Baseball means no flash so I would agree 85mm f1.8 or 135mm f2 unless you can get 200mm f1.8 or the newer 200mm f2 IS. Even then you will be at the higest ISOs. Fuji XT-1, 18-55mm
NokKeen Mostly Lurking 16 posts Joined Jul 2010 More info | Jul 16, 2010 17:49 | #7 BaseballPhotography44 wrote in post #10549891 Any tips would be great on shooting high action with little light. I am using a 1d Mark ii w/ a 70-200mm L F4 every time I have shot at night it dosent work out well so figured I would see advice from the experts! Use Iso 12800 all the time
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | Jul 16, 2010 17:52 | #8 BaseballPhotography44 wrote in post #10549891 Any tips would be great on shooting high action with little light. I am using a 1d Mark ii w/ a 70-200mm L F4 every time I have shot at night it dosent work out well so figured I would see advice from the experts! Just keep cranking that ISO and until you get your shutter speed fast enough to stop action.
JeffreyG "my bits and pieces are all hard" More info | Jul 16, 2010 21:01 | #9 Worth poiting out, baseball at night can be shot for journalistic purposes but you will never capture pretty images of the athletes at night no matter what gear and settings you use. The combination of lights above the field with baseball caps mean you will have ugly shadows that obscure the eyes of the players in every shot. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
| Latest registered member is Mihai Bucur 1440 guests, 112 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
